주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
소개
Follow this guide to replace a cracked or damaged rear panel on the Nintendo Switch.
  1. Before you begin this repair, make sure the device is completely powered off. Press and hold down the small round button on the back of the Joy Con controller. While you hold down the button, slide  the controller upward.
    • Before you begin this repair, make sure the device is completely powered off.
    • Press and hold down the small round button on the back of the Joy Con controller.
    • While you hold down the button, slide the controller upward.
  2. Continue sliding the controller upward until it's completely removed from the console. Repeat this same process for the other controller. Repeat this same process for the other controller.
    • Continue sliding the controller upward until it's completely removed from the console.
    • Repeat this same process for the other controller.
    • Use a Y00 screwdriver to remove the four 6.3 mm-long screws securing the rear panel.
  3. Use a JIS 000 screwdriver to remove the following screws securing the rear panel: One 2.5 mm-long screw on the top edge of the device
    • Use a JIS 000 screwdriver to remove the following screws securing the rear panel:
    • One 2.5 mm-long screw on the top edge of the device
    • Two 2.5 mm-long screws on the bottom edge of the device
  4. Use a JIS 000 screwdriver to remove the two 3.8 mm center screws on the sides of the device (one on each side). Use a JIS 000 screwdriver to remove the two 3.8 mm center screws on the sides of the device (one on each side).
    • Use a JIS 000 screwdriver to remove the two 3.8 mm center screws on the sides of the device (one on each side).
  5. Use your finger to flip up the kickstand on the back of the device. If there's a microSD card in the microSD card slot, remove it now before you continue to the next step.
    • Use your finger to flip up the kickstand on the back of the device.
    • If there's a microSD card in the microSD card slot, remove it now before you continue to the next step.
  6. Use a JIS 000 screwdriver to remove the 1.6 mm screw in the kickstand well.
    • Use a JIS 000 screwdriver to remove the 1.6 mm screw in the kickstand well.
  7. Lift the rear panel up from the bottom of the device and remove it. Lift the rear panel up from the bottom of the device and remove it. Lift the rear panel up from the bottom of the device and remove it.
    • Lift the rear panel up from the bottom of the device and remove it.
결론
Compare your new replacement part to the original part. You may need to transfer remaining components from the new part before installing.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Nintendo Switch Answers community for help.
다른 40명이 해당 안내서를 완성하였습니다.
Craig Lloyd
회원 가입일: 2016년 02월 10일
16,255 평판
안내서 80개 작성하였습니다
iFixit iFixit 회원
Community
133 회원들
안내서 14,606개 작성하였습니다
Excellent and concise guide.
The new panel doesn’t come with the sticky grille pieces x 2 on the bottom. Is it supposed to be a straight transfer between the old and the new?
Sal jUNK - 답글
Just did this replacement and there are a few things to keep in mind that this review does not mention. There are x2 square foam pieces that can be transferred to the new panel located at the bottom backside of the old. Also, the game cartridge shield hardware and the kickstand holder hardware have to be taken off the back of the old panel and transferred to the new panel. The kickstand has 2 Phillips #000 screws and the game cartridge shield has 1 Phillips #000 screw
Ryan Talbert - 답글
How do you transfer the foam pieces? Use some heat to loosen their adhesive and then remove them and transfer over the new backplate?
John - 답글
Is the casing the same between the HAC model and the HAD model? This guide doesn’t specify
Julian Webb - 답글
I am using iFixit Pro tool kit. What to do if one of the 000 screw’s cap appears to be stripped off? How to extract it if perchance?
Dr.Genuks - 답글
댓글 쓰기
조회 통계:
24 시간 전: 50
7일 전: 347
30일 전: 1,611
전체 시간: 28,955
