주요 콘텐츠로 건너뛰기
Nintendo Switch Rear Panel Replacement
필요한 것
  1. Nintendo Switch Rear Panel Replacement, Release the Joy Con controller locking tabs: 1 단계, 이미지 1/3 Nintendo Switch Rear Panel Replacement, Release the Joy Con controller locking tabs: 1 단계, 이미지 2/3 Nintendo Switch Rear Panel Replacement, Release the Joy Con controller locking tabs: 1 단계, 이미지 3/3
    • Before you begin this repair, make sure the device is completely powered off.
    • Press and hold down the small round button on the back of the Joy Con controller.
    • While you hold down the button, slide the controller upward.
  2. Nintendo Switch Rear Panel Replacement, Remove the Joy Con controllers: 2 단계, 이미지 1/3 Nintendo Switch Rear Panel Replacement, Remove the Joy Con controllers: 2 단계, 이미지 2/3 Nintendo Switch Rear Panel Replacement, Remove the Joy Con controllers: 2 단계, 이미지 3/3
    • Continue sliding the controller upward until it's completely removed from the console.
    • Repeat this same process for the other controller.
  3. Nintendo Switch Rear Panel Replacement, Remove the back-side screws: 3 단계, 이미지 1/1
    이 단계에 사용된 도구:
    Magnetic Project Mat
    $19.95
    구매
    • Use a Y00 screwdriver to remove the four 6.3 mm-long screws securing the rear panel.
  4. Nintendo Switch Rear Panel Replacement, Remove the top and bottom screws: 4 단계, 이미지 1/2 Nintendo Switch Rear Panel Replacement, Remove the top and bottom screws: 4 단계, 이미지 2/2
    • Use a JIS 000 screwdriver to remove the following screws securing the rear panel:
    • One 2.5 mm-long screw on the top edge of the device
    • Two 2.5 mm-long screws on the bottom edge of the device
  5. Nintendo Switch Rear Panel Replacement: 5 단계, 이미지 1/2 Nintendo Switch Rear Panel Replacement: 5 단계, 이미지 2/2
    • Use a JIS 000 screwdriver to remove the two 3.8 mm center screws on the sides of the device (one on each side).
  6. Nintendo Switch Rear Panel Replacement: 6 단계, 이미지 1/2 Nintendo Switch Rear Panel Replacement: 6 단계, 이미지 2/2
    • Use your finger to flip up the kickstand on the back of the device.
    • If there's a microSD card in the microSD card slot, remove it now before you continue to the next step.
  7. Nintendo Switch Rear Panel Replacement: 7 단계, 이미지 1/1
    • Use a JIS 000 screwdriver to remove the 1.6 mm screw in the kickstand well.
  8. Nintendo Switch Rear Panel Replacement: 8 단계, 이미지 1/3 Nintendo Switch Rear Panel Replacement: 8 단계, 이미지 2/3 Nintendo Switch Rear Panel Replacement: 8 단계, 이미지 3/3
    • Open the game card cartridge flap.
    • The game card cartridge flap attaches to the other half of the plastic shell, preventing you from completely lifting up the rear panel if it's closed.
    • Lift the rear panel up from the bottom of the device and remove it.
결론
Compare your new replacement part to the original part. You may need to transfer remaining components from the new part before installing.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Nintendo Switch Answers community for help.
다른 75명이 해당 안내서를 완성하였습니다.
Craig Lloyd
회원 가입일: 02/10/16
35,543 평판
안내서 82개 작성하였습니다
댓글 10개
Excellent and concise guide.
The new panel doesn’t come with the sticky grille pieces x 2 on the bottom. Is it supposed to be a straight transfer between the old and the new?
fclbriat123 - 답글
You can transfer the grill to the new back plat
Phillip Norton -
Just did this replacement and there are a few things to keep in mind that this review does not mention. There are x2 square foam pieces that can be transferred to the new panel located at the bottom backside of the old. Also, the game cartridge shield hardware and the kickstand holder hardware have to be taken off the back of the old panel and transferred to the new panel. The kickstand has 2 Phillips #000 screws and the game cartridge shield has 1 Phillips #000 screw
Ryan Talbert - 답글
How do you transfer the foam pieces? Use some heat to loosen their adhesive and then remove them and transfer over the new backplate?
John - 답글
Is the casing the same between the HAC model and the HAD model? This guide doesn’t specify
Julian Webb - 답글
댓글 쓰기
조회 통계:
24 시간 전: 50
7일 전: 338
30일 전: 1,513
전체 시간: 92,496
