주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nintendo Switch Right Joy-Con Shell Replacement
필요한 것
    1. Nintendo Switch Right Joy-Con Shell Replacement, Right Joy-Con Shell: 1 단계, 이미지 1개 중 1개
      • Remove the 4 tri-point screws on the back of the Joy-Con.
      • These are the only tri-point screws on the Joy-Con. All other screws require a Phillips head screwdriver.
      • These screws are incredibly easy to strip. Apply constant downward pressure while unscrewing them.
      댓글 쓰기
    2. Nintendo Switch Right Joy-Con Shell Replacement: 2 단계, 이미지 1개 중 1개
      • Flip open the back shell to expose the battery.
      댓글 쓰기
    3. Nintendo Switch Right Joy-Con Shell Replacement: 3 단계, 이미지 2개 중 1개 Nintendo Switch Right Joy-Con Shell Replacement: 3 단계, 이미지 2개 중 2개
      • Remove the screw connecting the rail to the back shell.
      댓글 쓰기
    4. Nintendo Switch Right Joy-Con Shell Replacement: 4 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      • Remove the battery and disconnect it from the motherboard. You may use tweezers or your hands to pull connections from the motherboard.
      • The battery may be difficult to remove due to adhesive. A spudger may help to detach it from the casing.
      댓글 쓰기
    5. Nintendo Switch Right Joy-Con Shell Replacement: 5 단계, 이미지 2개 중 1개 Nintendo Switch Right Joy-Con Shell Replacement: 5 단계, 이미지 2개 중 2개
      • Before performing the next step, take note of how the antenna cable is seated for proper reassembly.
      • Remove the small antenna chip (shown in second picture) and disconnect it from the motherboard.
      댓글 쓰기
    6. Nintendo Switch Right Joy-Con Shell Replacement: 6 단계, 이미지 1개 중 1개
      • Remove the 3 screws holding the battery casing in the shell.
      댓글 쓰기
    7. Nintendo Switch Right Joy-Con Shell Replacement: 7 단계, 이미지 3개 중 1개 Nintendo Switch Right Joy-Con Shell Replacement: 7 단계, 이미지 3개 중 2개 Nintendo Switch Right Joy-Con Shell Replacement: 7 단계, 이미지 3개 중 3개
      • Remove the ribbon cables connecting the rail and battery casing to the motherboard. Unlock the cables by flipping the connector upwards with a spudger, then pull the cable out of the connector.
      • You may even choose to leave the rail connected, though it will be unwieldy.
      • Be careful not to lift the connectors in the wrong direction. The connection nearest to the shoulder buttons lifts up away from the rail (the black part), and the connection nearest to the rumble motor lifts in the opposite direction, up toward the rail (the thin grey part.)
      댓글 쓰기
    8. Nintendo Switch Right Joy-Con Shell Replacement: 8 단계, 이미지 3개 중 1개 Nintendo Switch Right Joy-Con Shell Replacement: 8 단계, 이미지 3개 중 2개 Nintendo Switch Right Joy-Con Shell Replacement: 8 단계, 이미지 3개 중 3개
      • Remove the rumble motor by disconnecting the white 2-pin connector.
      댓글 쓰기
    9. Nintendo Switch Right Joy-Con Shell Replacement: 9 단계, 이미지 3개 중 1개 Nintendo Switch Right Joy-Con Shell Replacement: 9 단계, 이미지 3개 중 2개 Nintendo Switch Right Joy-Con Shell Replacement: 9 단계, 이미지 3개 중 3개
      • Remove the black ZR button from the battery casing.
      • Remove the button sensor by unscrewing it from the battery casing.
      댓글 쓰기
    10. Nintendo Switch Right Joy-Con Shell Replacement: 10 단계, 이미지 2개 중 1개 Nintendo Switch Right Joy-Con Shell Replacement: 10 단계, 이미지 2개 중 2개
      • Remove the two Phillips screws holding the joystick to the motherboard.
      • Disconnect the joystick ribbon cable from the motherboard.
      댓글 쓰기
    11. Nintendo Switch Right Joy-Con Shell Replacement: 11 단계, 이미지 2개 중 1개 Nintendo Switch Right Joy-Con Shell Replacement: 11 단계, 이미지 2개 중 2개
      • Remove the two screws anchoring the motherboard to the shell.
      댓글 쓰기
    12. Nintendo Switch Right Joy-Con Shell Replacement: 12 단계, 이미지 1개 중 1개
      • Transfer all buttons to the replacement shell.
      • If any silicone button covers are missing, they may be stuck to the back of the motherboard.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 72명이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Matthew Cheney
회원 가입일: 01/16/20
1,321 평판
안내서 1개를 작성함
9가이드 댓글
Not quite as thorough as the other Joy-con tear down but always a handy thing to have, going by the pictures it gave me all the information I needed personally concerning the screws, so I was able to strip the whole controller down and swap it into another shell. It is straight forward once you get in to it and have to give the author their much deserved credit for posting this up!
Lee Whittaker - 답글 공유
Very good detailed guide, only thing I would change is I’d probably take the rumble motor out right after of even before the battery. It’s pretty easy to remove, you can do it at anytime after opening, and it gets the wires out of the way to make other parts easier.
Dominic Garcia - 답글 공유
I am having difficulty removing the ribbon cable next to the rumble motor on step 7. It would be nice to have a photo of which way the clamp is expected to swing; I suspect I know the correct direction, but my tools are bending it instead.
earthexe - 답글 공유
In fact, this step is unnecessary unless you are replacing the buttons or rail case. The rail may remain attached if you are only replacing the front, back, and middle casing.
earthexe - 답글 공유
*attention* the r button can be very easily broken off when removing the pcb. It requires soldering skills to re attach it afterward.
Tthat1guy - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 33
지난 7일: 208
지난 30일: 892
전체 시간: 112,644
