이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Pull down on the battery cover release lever and pull back to remove the cover.
Remove the eight 9 mm screws from the back panel using the Tri-point Y1 screwdriver.
Carefully turn over the controller and place it on a flat surface.
Slowly separate the top panel from the bottom panel.
Once separated, set aside the top panel.
이 단계에 사용된 도구:Tweezers$4.99-
Using tweezers remove the three grey button pads from the motherboard.
With your fingers gently grip the motherboard on both sides and lift it away from the back panel.
Remove the four 9-mm Phillips head screws with the Phillips #1 screwdriver.
Lift off the black plastic covers that secure the shoulder buttons.
Using the screwdriver, carefully unlock the spring clip from its holder.
Once unlocked, use tweezers to pull springs out of its holster.
Once the spring is removed, take out the shoulder buttons by pulling down and out.
다른 4명이 해당 안내서를 완성하였습니다.
댓글 한 개
Where can I buy replacement shoulder buttons? Mine are starting to get sticky and don't spring back as well as they used to. I've been looking but I can't seem to find them anywhere.
