이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Use a metal spudger to remove the white plastic screw covers stuck to the lower case near the front of the Wii.
Remove the two 8.3 mm Tri-Point screws hidden under the covers you just removed.
Remove the single 5.9 mm Phillips screw under the controller port door nearest the faceplate.
Use a metal spudger to remove the rubber foot stuck to the side of the Wii near the DVD drive opening.
Remove the single 5.9 mm Phillips screw hidden under the foot you just removed.
Carefully pull the faceplate away from the front of the Wii.
Use a pair of tweezers to disconnect the LED cable's plastic connector from the motherboard.
Remove the faceplate.
Open the controller port cover until it is perpendicular to the black controller port bezel.
Pull the controller port cover straight up to release it from the outer case.
Remove the two remaining 4.1 mm Phillips screws along the top edge of the black plastic controller port bezel.
Lift the bezel from the long edge furthest away from the controller ports and remove it from the Wii.
Use a metal spudger to remove the three highlighted screw covers stuck to the side of the Wii.
Remove the following screws:
Two 5 mm Phillips screws
One 8.2 mm Tri-Point screw
Use a metal spudger to remove the two rubber feet stuck to the bottom face of the Wii near the rear ports.
Remove the two 8.2 mm Tri-Point screws hidden under the feet you just removed.
Remove the small Phillips screw securing the battery door to the bottom panel.
Pull the battery door out of the Wii.
Remove the 8.2 mm Tri-Point screw that was hidden beneath the battery door.
Remove the two 8.2 mm Tri-Point screws securing the DVD drive shield near the controller ports.
Remove the four 9 mm #1 Phillips screws securing the DVD drive to the bottom panel.
Lift the side of the DVD drive opposite the controller ports enough to access the cables on its bottom face.
Carefully pull the DVD drive power cable out from under the plastic shroud near the heat sink.
Use your fingernail to flip up the retaining flap on the DVD drive ribbon cable socket.
Pull the DVD drive ribbon cable out of its socket.
Remove the DVD drive from the Wii.
Measure across each fuse with a continuity meter.
If either fuse is open, you will need to replace it with an 0603 fuse; if one is not available, you can use a 0-ohm resistor or jumper wire for testing purposes.
다른 15명이 해당 안내서를 완성하였습니다.
댓글 4개
Soldering jumpers on those fuses is easier said than done. The left-hand fuse follows the same trace all the way to the larger solder pad above, so don't worry about bridging. But it looks like there's a cap or diode along the trace of the right-hand fuse, so solder carefully! This worked great, and got my Wii drive back to spinning without spending $80 on a new drive.
If anyone could give specifications for the fuses needed, it would be very much appreciated... 0603 Fuses come in different amp ratings. I saw one person suggest elsewhere that after research he found that the ones used in this repair are 2A 0603 fuses, can anyone confirm this please before I get the wrong ones?
Thanks in advance,
James @ Retro Gaming Repair UK
I found a datasheet for littelfuse which labels the fuse as 2A. The datasheet can be found here
http://www.littelfuse.com/data/en/data_s....
Hope this helps.
Another tip for after you know the fuse is blown instead of removing the fuse and jumpering it add a little solder on both sides of the fuse then use a lead from a resister heating up the solder and push the lead from a resistor into it then do the same for the other side.
randyhenke - 답글
this guide assumes you have one revision of the board....i have another revision and can only find one of the resistors
