주요 콘텐츠로 건너뛰기
이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
Nintendo Wii Faceplate Replacement
필요한 것
  1. Nintendo Wii Faceplate Replacement, Faceplate: 1 단계, 이미지 1/2 Nintendo Wii Faceplate Replacement, Faceplate: 1 단계, 이미지 2/2
    • Use a metal spudger to remove the white plastic screw covers stuck to the lower case near the front of the Wii.
  2. Nintendo Wii Faceplate Replacement: 2 단계, 이미지 1/1
    • Remove the two 8.3 mm Tri-Wing screws hidden under the covers you just removed.
  3. Nintendo Wii Faceplate Replacement: 3 단계, 이미지 1/1
    • Remove the single 5.9 mm Phillips screw under the controller port door nearest the faceplate.
  4. Nintendo Wii Faceplate Replacement: 4 단계, 이미지 1/1
    • Use a metal spudger to remove the rubber foot stuck to the side of the Wii near the DVD drive opening.
  5. Nintendo Wii Faceplate Replacement: 5 단계, 이미지 1/1
    • Remove the single 5.9 mm Phillips screw hidden under the foot you just removed.
  6. Nintendo Wii Faceplate Replacement: 6 단계, 이미지 1/2 Nintendo Wii Faceplate Replacement: 6 단계, 이미지 2/2
    • Carefully pull the faceplate away from the front of the Wii.
    • Use a pair of tweezers to disconnect the LED cable's plastic connector from the motherboard.
    • Remove the faceplate.
결론
다른 22명이 해당 안내서를 완성하였습니다.
Andrew Bookholt
586,109 평판
안내서 619개 작성하였습니다
댓글 3개
Any more to do if pressing the on button does nothing, its still red power light?
Kyrre - 답글
Tanks for this guide Btw
Kyrre - 답글
Thanks for the guide, I just wish it continued with replacing the components within the faceplate, as I wanted to replace the white shell. Still helpful though!
Cynthia - 답글
댓글 쓰기
조회 통계:
24 시간 전: 5
7일 전: 46
30일 전: 341
전체 시간: 53,301
