소개
Use this guide to remove the heat sink from your Wii's motherboard.
Use a metal spudger to remove the white plastic screw covers stuck to the lower case near the front of the Wii.
Open the controller port cover until it is perpendicular to the black controller port bezel.
Pull the controller port cover straight up to release it from the outer case.
Remove the small Phillips screw securing the battery door to the bottom panel.
Pull the battery door out of the Wii.
Use a pair of tweezers to lift the fan connector up and out of its socket on the logic board.
Remove the four 11.3 mm Phillips screws securing the heat sink to the bottom panel.
다른 13명이 해당 안내서를 완성하였습니다.
댓글 5개
This guide also works great as a thermal paste replacement guide for the Wii, just remove the old thermal pads and clean off the heatsink, CPU, GPU, and WiFi board, and apply Thermal Grease to the CPU, GPU, And WiFi board.
Worked great! Was able to reapply thermal paste on my wii. It’s working great so far!
Can we use Thermal Paste instead of Thermal Pads?
Yes, thermal paste can be used. I strongly recommend Thermal Grizzly Kryonaut, as it’s the second-best-performing non-metallic thermal paste on the market (the only better performer is Kryonaut Extreme).
What are the dimensions of the thermal pads that we should use?
