주요 콘텐츠로 건너뛰기
Nintendo Wii Outer Case Replacement
필요한 것
  1. Nintendo Wii Outer Case Replacement, Faceplate: 1 단계, 이미지 1/2 Nintendo Wii Outer Case Replacement, Faceplate: 1 단계, 이미지 2/2
    • Use a metal spudger to remove the white plastic screw covers stuck to the lower case near the front of the Wii.
  2. Nintendo Wii Outer Case Replacement: 2 단계, 이미지 1/1
    • Remove the two 8.3 mm Tri-Point screws hidden under the covers you just removed.
  3. Nintendo Wii Outer Case Replacement: 3 단계, 이미지 1/1
    • Remove the single 5.9 mm Phillips screw under the controller port door nearest the faceplate.
  4. Nintendo Wii Outer Case Replacement: 4 단계, 이미지 1/1
    • Use a metal spudger to remove the rubber foot stuck to the side of the Wii near the DVD drive opening.
  5. Nintendo Wii Outer Case Replacement: 5 단계, 이미지 1/1
    • Remove the single 5.9 mm Phillips screw hidden under the foot you just removed.
  6. Nintendo Wii Outer Case Replacement: 6 단계, 이미지 1/2 Nintendo Wii Outer Case Replacement: 6 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Carefully pull the faceplate away from the front of the Wii.
    • Use a pair of tweezers to disconnect the LED cable's plastic connector from the motherboard.
    • Remove the faceplate.
  7. Nintendo Wii Outer Case Replacement, Outer Case: 7 단계, 이미지 1/3 Nintendo Wii Outer Case Replacement, Outer Case: 7 단계, 이미지 2/3 Nintendo Wii Outer Case Replacement, Outer Case: 7 단계, 이미지 3/3
    • Open the controller port cover until it is perpendicular to the black controller port bezel.
    • Pull the controller port cover straight up to release it from the outer case.
    • Repeat this procedure for the memory card port cover.
  8. Nintendo Wii Outer Case Replacement: 8 단계, 이미지 1/2 Nintendo Wii Outer Case Replacement: 8 단계, 이미지 2/2
    • Remove the two remaining 4.1 mm Phillips screws along the top edge of the black plastic controller port bezel.
    • Lift the bezel from the long edge furthest away from the controller ports and remove it from the Wii.
  9. Nintendo Wii Outer Case Replacement: 9 단계, 이미지 1/1
    • Remove the two 5 mm Phillips screws above the controller ports.
  10. Nintendo Wii Outer Case Replacement: 10 단계, 이미지 1/1
    • Use a metal spudger to remove the three highlighted screw covers stuck to the side of the Wii.
  11. Nintendo Wii Outer Case Replacement: 11 단계, 이미지 1/1
    • Remove the following screws:
    • Two 5 mm Phillips screws
    • One 8.2 mm Tri-Point screw
  12. Nintendo Wii Outer Case Replacement: 12 단계, 이미지 1/1
    • Use a metal spudger to remove the two rubber feet stuck to the bottom face of the Wii near the rear ports.
  13. Nintendo Wii Outer Case Replacement: 13 단계, 이미지 1/1
    • Remove the two 8.2 mm Tri-Point screws hidden under the feet you just removed.
    • You may use a 4 mm hex driver to extend your bit into the recesses and reach the screws.
  14. Nintendo Wii Outer Case Replacement: 14 단계, 이미지 1/1
    • Lift the outer case straight up off the body of the Wii.
결론
다른 37명이 해당 안내서를 완성하였습니다.
Andrew Bookholt
587,996 평판
안내서 619개 작성하였습니다
댓글 4개
Great guide. I had no problems.
wewomack - 답글
Ugh, I went and purchased an iFixit Essential Electronics Toolkit and the Tri-wing screwdriver is too small! Y000 is what it says on the box, time to return this purchase.
iamstilllaughing - 답글
Unfortunately this guide stops half way through and doesn’t include the other side of the case, which involves quite a few screws as the motherboard is screwed down in quite a few places, and the cpu heatsink has to come up, it’s much more complicated than this.
Lily Larceny - 답글
yes i would love if the poster edited the guide and made it so it could be used as a "reshell" guide because i am considering purchaseing a lower condition wii and reshelling it in another color
Sqwerks -
댓글 쓰기
조회 통계:
24 시간 전: 12
7일 전: 81
30일 전: 487
전체 시간: 46,542
