주요 콘텐츠로 건너뛰기
Nintendo Wii Remote Disassembly and Corrosion Cleaning
필요한 것
  1. Nintendo Wii Remote Disassembly and Corrosion Cleaning, Nintendo Wii Remote Disassembly and Corrosion Cleaning: 1 단계, 이미지 1/3 Nintendo Wii Remote Disassembly and Corrosion Cleaning, Nintendo Wii Remote Disassembly and Corrosion Cleaning: 1 단계, 이미지 2/3 Nintendo Wii Remote Disassembly and Corrosion Cleaning, Nintendo Wii Remote Disassembly and Corrosion Cleaning: 1 단계, 이미지 3/3
    • Remove the battery cover and the batteries.
    • Remove the four tri-point Y1 screws holding the remote together.
  2. Nintendo Wii Remote Disassembly and Corrosion Cleaning: 2 단계, 이미지 1/3 Nintendo Wii Remote Disassembly and Corrosion Cleaning: 2 단계, 이미지 2/3 Nintendo Wii Remote Disassembly and Corrosion Cleaning: 2 단계, 이미지 3/3
    • Using an opening tool, apply pressure to the tabs located near the "A" button.
    • The tabs can break, but the remote will still work even if they do break.
    • Remove the faceplate.
  3. Nintendo Wii Remote Disassembly and Corrosion Cleaning: 3 단계, 이미지 1/3 Nintendo Wii Remote Disassembly and Corrosion Cleaning: 3 단계, 이미지 2/3 Nintendo Wii Remote Disassembly and Corrosion Cleaning: 3 단계, 이미지 3/3
    • To remove the motherboard, press up on the "B" button, and then the connector at the bottom.
  4. Nintendo Wii Remote Disassembly and Corrosion Cleaning: 4 단계, 이미지 1/3 Nintendo Wii Remote Disassembly and Corrosion Cleaning: 4 단계, 이미지 2/3 Nintendo Wii Remote Disassembly and Corrosion Cleaning: 4 단계, 이미지 3/3
    • Unclip the tabs to remove the plastic piece.
    • On the back, move the vibration motor out of the way to completely remove the plastic piece.
  5. Nintendo Wii Remote Disassembly and Corrosion Cleaning: 5 단계, 이미지 1/3 Nintendo Wii Remote Disassembly and Corrosion Cleaning: 5 단계, 이미지 2/3 Nintendo Wii Remote Disassembly and Corrosion Cleaning: 5 단계, 이미지 3/3
    • Find any corrosion on the motherboard.
    • Corrosion on the motherboard will have a blueish color and may appear in multiple places.
    • Check the battery terminals for corrosion.
    • If batteries leaked in the remote, there will be corrosion on the terminals.
  6. Nintendo Wii Remote Disassembly and Corrosion Cleaning: 6 단계, 이미지 1/3 Nintendo Wii Remote Disassembly and Corrosion Cleaning: 6 단계, 이미지 2/3 Nintendo Wii Remote Disassembly and Corrosion Cleaning: 6 단계, 이미지 3/3
    • Clean the corroded areas with isopropyl alcohol and a toothbrush.
    • Q-tips can be used instead of a toothbrush.
    • Cleaning won't make look it perfect, but the remote will work again.
  7. Nintendo Wii Remote Disassembly and Corrosion Cleaning: 7 단계, 이미지 1/2 Nintendo Wii Remote Disassembly and Corrosion Cleaning: 7 단계, 이미지 2/2
    • Clean the terminals with isopropyl alcohol and a toothbrush or Q-tips.
    • It is difficult to remove this piece, so clean it as good as you can. Using more isopropyl alcohol helps here.
결론
다른 11명이 해당 안내서를 완성하였습니다.
Stefan Kula
회원 가입일: 03/21/21
469 평판
안내서 1개 작성함
댓글 2개
Would 99% Isopropyl Alcohol also be okay to use as cleaner?
Mirela - 답글
Of course, I use this for cleaning every type of motherboard, the difference between 99% and 70% is that the solution contains less water, so the liquid evaporate in less time :)
ReDeath_ -
댓글 쓰기
조회 통계:
24 시간 전: 15
7일 전: 197
30일 전: 853
전체 시간: 19,474
