주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Nintendo Wii Remote 수리는 저희 서비스 설명서를 사용하십시오.
  1. Rock Candy Remote Teardown, Getting your control: 1 단계, 이미지 1/3 Rock Candy Remote Teardown, Getting your control: 1 단계, 이미지 2/3 Rock Candy Remote Teardown, Getting your control: 1 단계, 이미지 3/3
    • To start dissembling this wii remote, turn it over and take the back off.
  2. Rock Candy Remote Teardown, Unscrewing the screws: 2 단계, 이미지 1/3 Rock Candy Remote Teardown, Unscrewing the screws: 2 단계, 이미지 2/3 Rock Candy Remote Teardown, Unscrewing the screws: 2 단계, 이미지 3/3
    • Then take the screws out and pry off the back, you should have four screws, 2 from the top and 2 from the bottom.
  3. Rock Candy Remote Teardown, Opening the control: 3 단계, 이미지 1/3 Rock Candy Remote Teardown, Opening the control: 3 단계, 이미지 2/3 Rock Candy Remote Teardown, Opening the control: 3 단계, 이미지 3/3
    • You need to pry off the back (do this carefully) , open it in half it should look like this (second picture). Take the motherboard off slowly and carefully, you should have 3 parts (third picture)
  4. Rock Candy Remote Teardown, Taking out the buttons: 4 단계, 이미지 1/3 Rock Candy Remote Teardown, Taking out the buttons: 4 단계, 이미지 2/3 Rock Candy Remote Teardown, Taking out the buttons: 4 단계, 이미지 3/3
    • From this part of the control take these pieces off carefully. You should have these pieces (second picture). After you should have something that looks like this (third picture). You have successfully disassembled your wii remote.
    • This will show you how to reassembling the wii remote if you are having trouble.
Giovanni Terrones
회원 가입일: 04/25/19
181 평판
안내서 1개 작성함
댓글 2개
This guide is great but it’s for a knock off brand called Rock Candy which is different to the official Nintendo controllers :)
Winter Lacekels - 답글
it is not a knockoff it's from a 3rd party
Justin Case - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 12
30일 전: 59
전체 시간: 3,219
