주요 콘텐츠로 건너뛰기
Nintendo Wii Remote Front Cover Plate and Batteries Replacement
필요한 것
  1. Nintendo Wii Remote Front Cover Plate and Batteries Replacement, Front Cover Plate and Batteries: 1 단계, 이미지 1/2 Nintendo Wii Remote Front Cover Plate and Batteries Replacement, Front Cover Plate and Batteries: 1 단계, 이미지 2/2
    • Flip the Wii Remote over so the battery cover faces you.
    • Push up on the bottom tab.
    • Remove the battery cover.
  2. Nintendo Wii Remote Front Cover Plate and Batteries Replacement: 2 단계, 이미지 1/1
    • Remove the first battery by pressing down on the positive end and pulling the battery out.
    • Remove the second battery by pushing up on the positive end and pulling the battery out.
  3. Nintendo Wii Remote Front Cover Plate and Batteries Replacement: 3 단계, 이미지 1/1
    • Using a tri-point Y1 Screwdriver, remove the two center 7mm screws by turning them counterclockwise.
    • Repeat with the two bottom screws.
  4. Nintendo Wii Remote Front Cover Plate and Batteries Replacement: 4 단계, 이미지 1/2 Nintendo Wii Remote Front Cover Plate and Batteries Replacement: 4 단계, 이미지 2/2
    • With the flat end of a spudger, gently apply pressure to the tabs located on left side of the controller.
    • These tabs are breakable. However, if the tabs are broken the controller will still function.
    • Open the front plate like a book.
    • Small parts may fall out as you open the front plate.
    Mine is not opening like a book? What do I do?
    Micah Thompson - 답글
    It stops short of explaining replacing rechargeable battery. Unless you’re referring to the AA’s which don’t involve removing cover
    Sticky Insides - 답글
결론
다른 36명이 해당 안내서를 완성하였습니다.
Emily
회원 가입일: 04/14/13
1,509 평판
안내서 6개 작성하였습니다
Cal Poly, Team 3-44, Amido Spring 2013 Cal Poly, Team 3-44, Amido Spring 2013 회원
CPSU-AMIDO-S13S3G44
4 회원들
안내서 26개 작성하였습니다
댓글 4개
Worked! Had to solder the tab to contact the battery which had broken. Saved $50.00.
Graham Poor - 답글
The Tools section lists a Tri-Point Y1 Screwdriver but the guide mentions a Tri-Wing Y1 Screwdriver. This could cause people to purchase the wrong item.
iFixit’s guides seem to be based on the original Wii controller, model RVL-003. I’m not sure if Nintendo has changed fasteners for subsequent versions but the Wii MotionPlus Controller, model RVL-036, uses a Tri-Wing Y0 screw.
kivrin - 답글
@kivrin Thanks for your comment. I’m pretty sure it should say tri-point, not tri-wing. I’ll update the instructions. Tri-wing screws have a more twisted/triangular form factor, like this.
Jeff Suovanen -
My controller (the original) had three tri-wing screws and one philips. Not sure why. Had to re-solder the negative battery terminal as it came off the bottom of the ‘top’ (faces bottom) of the board.
audvare - 답글
댓글 쓰기
조회 통계:
24 시간 전: 32
7일 전: 244
30일 전: 1,305
전체 시간: 103,313
