주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nintendo Wii Remote Main Buttons Replacement
필요한 것
  1. Nintendo Wii Remote Main Buttons Replacement, Front Cover Plate and Batteries: 1 단계, 이미지 2개 중 1개 Nintendo Wii Remote Main Buttons Replacement, Front Cover Plate and Batteries: 1 단계, 이미지 2개 중 2개
    • Flip the Wii Remote over so the battery cover faces you.
    • Push up on the bottom tab.
    • Remove the battery cover.
  2. Nintendo Wii Remote Main Buttons Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the first battery by pressing down on the positive end and pulling the battery out.
    • Remove the second battery by pushing up on the positive end and pulling the battery out.
  3. Nintendo Wii Remote Main Buttons Replacement: 3 단계, 이미지 1개 중 1개
    • Using a tri-point Y1 Screwdriver, remove the two center 7mm screws by turning them counterclockwise.
    • Repeat with the two bottom screws.
  4. Nintendo Wii Remote Main Buttons Replacement: 4 단계, 이미지 2개 중 1개 Nintendo Wii Remote Main Buttons Replacement: 4 단계, 이미지 2개 중 2개
    • With the flat end of a spudger, gently apply pressure to the tabs located on left side of the controller.
    • These tabs are breakable. However, if the tabs are broken the controller will still function.
    • Open the front plate like a book.
    • Small parts may fall out as you open the front plate.
  5. Nintendo Wii Remote Main Buttons Replacement, Main Buttons: 5 단계, 이미지 2개 중 1개 Nintendo Wii Remote Main Buttons Replacement, Main Buttons: 5 단계, 이미지 2개 중 2개
    • Working on the inside of the front cover, peel off the three rubber pads covering the buttons.
  6. Nintendo Wii Remote Main Buttons Replacement: 6 단계, 이미지 1개 중 1개
    • Flip over the cover, allowing the buttons to fall into your hand.
    • Be ready to catch all the buttons, some are very small. If a button does not fall out apply gentle pressure from behind.
    • When reassembling, put each plastic button in its allocated slot. Each button only fits snugly in one slot.
    • The best option for you is rotate the Wii Controller by 180°. If you obey this note, the small parts wont fall off and then you can remove the buttons.
결론
다른 27명이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Emily
회원 가입일: 04/14/13
2,010 평판
안내서 6개를 작성함
Cal Poly, Team 3-44, Amido Spring 2013 Cal Poly, Team 3-44, Amido Spring 2013 회원
CPSU-AMIDO-S13S3G44
4 회원들
안내서 29개를 작성함
5가이드 댓글
Where did you get your replacement buttons? I can't find them online anywhere...
devannedloss - 답글 공유
Me too, can’t find them.
Michael Velten - 답글 공유
2024 and can't find them online ANYWHERE! I'm hoping a WiiUDpad fits on the wiimote. You'd think there'd be a bunch of wiimote shells of different colours available everywhere online, but they're nowhere to be found
how frustrating!
MartianIsotopes - 답글 공유
Vinted is full of them. Although some people ask wayyy too much for them!
Sophie Nicholson - 답글 공유
Yo tampoco los encuentro por ninguna parte
kinoto taller - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 13
지난 7일: 57
지난 30일: 346
전체 시간: 48,781
