소개
Removing the main buttons requires opening the device. The main buttons include all buttons except the trigger style B button.
필요한 것
Flip the Wii Remote over so the battery cover faces you.
Push up on the bottom tab.
Remove the battery cover.
With the flat end of a spudger, gently apply pressure to the tabs located on left side of the controller.
Open the front plate like a book.
Mine is not opening like a book? What do I do?
It stops short of explaining replacing rechargeable battery. Unless you’re referring to the AA’s which don’t involve removing cover
Working on the inside of the front cover, peel off the three rubber pads covering the buttons.
다른 22명이 해당 안내서를 완성하였습니다.
댓글 4개
Where did you get your replacement buttons? I can't find them online anywhere...
Me too, can’t find them.
2024 and can't find them online ANYWHERE! I'm hoping a WiiUDpad fits on the wiimote. You'd think there'd be a bunch of wiimote shells of different colours available everywhere online, but they're nowhere to be found
how frustrating!
Vinted is full of them. Although some people ask wayyy too much for them!
