주요 콘텐츠로 건너뛰기
Fix Your Stuff
Right to Repair
Parts & Tools
소개
Use this guide to remove the outer case of the Nintendo Wii U and gain access to the DVD drive.
  1. With the bottom of the console facing up, remove the following 6 screws hidden underneath the white square stickers:
    • With the bottom of the console facing up, remove the following 6 screws hidden underneath the white square stickers:
    • Three 5.1mm Phillips #000 screws
    • Two 6.1mm Tri-wing Y0 screws
    • One 13.2mm Tri-wing Y1 screw
  2. Rotate the console 180 degrees so that the exhaust vents are facing you.
    • Rotate the console 180 degrees so that the exhaust vents are facing you.
    • Remove the two 7.1mm Phillips #00 screws.
  3. On the side opposite of the exhaust vents, slide the cover faceplate towards the back of the console and pull upwards to release it. On the side opposite of the exhaust vents, slide the cover faceplate towards the back of the console and pull upwards to release it.
    • On the side opposite of the exhaust vents, slide the cover faceplate towards the back of the console and pull upwards to release it.
  4. On the bottom of the console beneath the previously removed faceplate, remove the three 13.2mm Tri-wing Y1 screws.
    • On the bottom of the console beneath the previously removed faceplate, remove the three 13.2mm Tri-wing Y1 screws.
  5. On the back of the console, lift up and release the main top cover. On the back of the console, lift up and release the main top cover. On the back of the console, lift up and release the main top cover.
    • On the back of the console, lift up and release the main top cover.
결론
다른 16명이 해당 안내서를 완성하였습니다.
Kim Arre
회원 가입일: 2013년 01월 11일
3,497 평판
안내서 8개 작성하였습니다
Cal Poly, Team 17-20, Forte Winter 2013 Cal Poly, Team 17-20, Forte Winter 2013 회원
CPSU-FORTE-W13S17G20
5 회원들
안내서 19개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 33
30일 전: 176
전체 시간: 18,409
