주요 콘텐츠로 건너뛰기
기기를 고치세요
수리할 권리
부품 & 도구
소개
Use this guide to install a new DVD Drive for a Nintendo Wii U.
  1. With the bottom of the console facing up, remove the following 6 screws hidden underneath the white square stickers:
    • With the bottom of the console facing up, remove the following 6 screws hidden underneath the white square stickers:
    • Three 5.1mm Phillips #000 screws
    • Two 6.1mm Tri-wing Y0 screws
    • One 13.2mm Tri-wing Y1 screw
  2. Rotate the console 180 degrees so that the exhaust vents are facing you.
    • Rotate the console 180 degrees so that the exhaust vents are facing you.
    • Remove the two 7.1mm Phillips #00 screws.
  3. On the side opposite of the exhaust vents, slide the cover faceplate towards the back of the console and pull upwards to release it. On the side opposite of the exhaust vents, slide the cover faceplate towards the back of the console and pull upwards to release it.
    • On the side opposite of the exhaust vents, slide the cover faceplate towards the back of the console and pull upwards to release it.
  4. On the bottom of the console beneath the previously removed faceplate, remove the three 13.2mm Tri-wing Y1 screws.
    • On the bottom of the console beneath the previously removed faceplate, remove the three 13.2mm Tri-wing Y1 screws.
  5. On the back of the console, lift up and release the main top cover. On the back of the console, lift up and release the main top cover. On the back of the console, lift up and release the main top cover.
    • On the back of the console, lift up and release the main top cover.
  6. Rotate the device so that the front plate is facing you. On each side of the console, remove the 3.5mm Phillips #0 screw connecting the DVD drive to the faceplate.
    • Rotate the device so that the front plate is facing you.
    • On each side of the console, remove the 3.5mm Phillips #0 screw connecting the DVD drive to the faceplate.
  7. Rotate the device so that the front plate is on the right side and the ribbon cable is visible.
    • Rotate the device so that the front plate is on the right side and the ribbon cable is visible.
    • Lift up on the blue tab to release the ribbon cable.
  8. Remove the front faceplate.
    • Remove the front faceplate.
  9. On each side of the DVD drive, remove the two 4.6mm Phillips #0 mounting screws.
    • On each side of the DVD drive, remove the two 4.6mm Phillips #0 mounting screws.
  10. Rotate the device so that the DVD slot is visible. A ribbon cable is attached to the bottom right side of the DVD drive. The ribbon cable can rip if it isn't removed properly.
    • Rotate the device so that the DVD slot is visible.
    • A ribbon cable is attached to the bottom right side of the DVD drive. The ribbon cable can rip if it isn't removed properly.
    • Lift the DVD drive out of the mount and turn over to the right so it lies like a book.
    • Use a spudger to release the ribbon cable.
  11. Remove the CD drive.
    • Remove the CD drive.
결론
다른 38명이 해당 안내서를 완성하였습니다.
Kim Arre
회원 가입일: 2013년 01월 11일
3,524 평판
안내서 8개 작성하였습니다
Cal Poly, Team 17-20, Forte Winter 2013 Cal Poly, Team 17-20, Forte Winter 2013 회원
CPSU-FORTE-W13S17G20
5 회원들
안내서 19개 작성하였습니다
I've done with twice with two different drives ordered on Ebay, and keep getting the same error code (160-1402). Is the place I'm buying from selling bad drives, or is there something else that needs to be done after? It goes back to working when I put my old one back in, so I know I'm physically doing it correctly.
Brad Senatore - 답글
Update : For anybody else having this problem, you have to change out the logic board from your old drive to the new one. Pain in the neck, but works!
Brad Senatore -
What do you mean by change out the logic board?
gingindua -
the logic board is inside the disk drive. Remove it and replace it into the new disk drive. This is the same on the Xbox and Playstation
rehrnsberger -
Did an update it failed rebooted and now get a 160-1402. With the DVD drive cover off the Spindle isnt moving. Suspect Drive would seem 160-XXXX is DVD Drive related Errors
Ben Uwins - 답글
댓글 쓰기
조회 통계:
24 시간 전: 17
7일 전: 91
30일 전: 435
전체 시간: 54,263
