주요 콘텐츠로 건너뛰기
Nintendo Wii U Fan Replacement
필요한 것
  1. Nintendo Wii U Fan Replacement, Remove Stickers Covering Screws: 1 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Using a flathead screwdriver, spudger, or tweezers, remove the stickers covering the screws on the bottom of the Wii U and on the side of the Wii U.
    • Do not try to use your fingernails. It would only hurt.
  2. Nintendo Wii U Fan Replacement, Unscrew All of the Screws on the Back of the Wii U: 2 단계, 이미지 3개 중 1개 Nintendo Wii U Fan Replacement, Unscrew All of the Screws on the Back of the Wii U: 2 단계, 이미지 3개 중 2개 Nintendo Wii U Fan Replacement, Unscrew All of the Screws on the Back of the Wii U: 2 단계, 이미지 3개 중 3개
    • Remove three Phillips screws with a Phillips #00 screwdriver.
    • Remove three Tri-Wing screws with a Y1 Tri-Wing screwdriver.
  3. Nintendo Wii U Fan Replacement, Remove the Battery: 3 단계, 이미지 2개 중 1개 Nintendo Wii U Fan Replacement, Remove the Battery: 3 단계, 이미지 2개 중 2개
    • To remove the battery, unscrew the screw holding it in place with a Phillips #00 screwdriver.
    • Then pull the battery free.
    • Once you reassemble the Wii U, you might need to set the date and time.
  4. Nintendo Wii U Fan Replacement, Unscrew the Screws on the Side of the Wii U: 4 단계, 이미지 2개 중 1개 Nintendo Wii U Fan Replacement, Unscrew the Screws on the Side of the Wii U: 4 단계, 이미지 2개 중 2개
    • Unscrew the two screws on the side of the Wii U near the air vents with a Phillips #00 screwdriver.
    • EDIT 9/26/16: There are stickers covering these screws too. Remove them.
  5. Nintendo Wii U Fan Replacement, Pull off the Side Cover: 5 단계, 이미지 3개 중 1개 Nintendo Wii U Fan Replacement, Pull off the Side Cover: 5 단계, 이미지 3개 중 2개 Nintendo Wii U Fan Replacement, Pull off the Side Cover: 5 단계, 이미지 3개 중 3개
    • Slide the side cover to your right.
    • Lift the side cover off.
  6. Nintendo Wii U Fan Replacement, Unscrew the Screws Under the Side Cover: 6 단계, 이미지 1개 중 1개
  7. Nintendo Wii U Fan Replacement, Removing the Top Cover: 7 단계, 이미지 3개 중 1개 Nintendo Wii U Fan Replacement, Removing the Top Cover: 7 단계, 이미지 3개 중 2개 Nintendo Wii U Fan Replacement, Removing the Top Cover: 7 단계, 이미지 3개 중 3개
    • Lift the top cover.
    • Pull the top cover towards you.
    • Do not lift the top cover up all the way at first! Make sure to pull it towards you (shown in picture #2 and the video on the next step), then lift it up all the way. If you don't remove the top cover this way, U may damage your U. ):
    • Video of removing the top cover.
  8. Nintendo Wii U Fan Replacement, Removing the Fan: 9 단계, 이미지 3개 중 1개 Nintendo Wii U Fan Replacement, Removing the Fan: 9 단계, 이미지 3개 중 2개 Nintendo Wii U Fan Replacement, Removing the Fan: 9 단계, 이미지 3개 중 3개
    • Remove the two Phillips screws securing the fan in place with a Phillips #00 screwdriver.
    • Use a magnet or a magnetic screwdriver to lift up the screws once they're fully loosened, as seen in the second picture.
    • Screwdrivers with a black tip usually mean that they're magnetic, as shown with the black arrow in the second picture.
    • Remove the fan from its socket.
    • Set the fan's wires free from under the clamp (see the yellow box on picture #3).
    • Unplug the fan's power cable by tugging on its wires.
    • Do not tug the fan.
    • Do not tug the wires from too far or else the wires/power connector may break.
결론
Congrats if you've made it this far! Click the button below if you successfully replaced your fan! To reassemble your Wii U, follow these instructions in reverse order. Note that you will not be able to put the stickers back on that were covering the screws on the bottom cover of the Wii U — well, who really cares about a sticker covering a screw!?
Thank you all for viewing this guide. Keep on fixing!
다른 38명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Reid Fleishman
회원 가입일: 02/12/16
1,546 평판
안내서 1개를 작성함
Master Techs Master Techs 회원
Community
327 회원들
안내서 1,699개를 작성함
댓글 7개
Is it red = +5V, black = GND, grey = ¿PWM? - can't find original fan to buy [don't want to order from overseas] so trying to go with a 40mm 5V replacement, reusing the original connector.
facebook - 답글
No that doesn't seem right. If someone knows the pinout with some certainty, please do tell.
facebook -
Here’s the fan pinout if someone’s going to splice in a new 40mm fan while reusing the original connector:
Black - Ground
Red - RPM signal
Grey - +5V
Ran across the pinout while splicing in a new 40mm fan because the original broke
Yevgney Sliosarenko - 답글
so, has anyone had any luck with replacing the stock fan with a noctua fan? I’m gonna try it myself and see if its any quieter since the stock fan is really loud
Joshua Bishell - 답글
No luck for me with Noctua fan unfortunately. But I suspect some defect with the WiiU itself. All fans always run at full blast for me. Tried Noctua, and Aliexpress replacement part which looks like original also same color wires.
facebook -
댓글 쓰기
조회 통계:
지난 24시간: 9
지난 7일: 65
지난 30일: 328
전체 시간: 21,576
