주요 콘텐츠로 건너뛰기
Nintendo Wii U GamePad Directional Pad Buttons Replacement
필요한 것
  1. Nintendo Wii U GamePad Directional Pad Buttons Replacement, Back Panel: 1 단계, 이미지 3개 중 1개 Nintendo Wii U GamePad Directional Pad Buttons Replacement, Back Panel: 1 단계, 이미지 3개 중 2개 Nintendo Wii U GamePad Directional Pad Buttons Replacement, Back Panel: 1 단계, 이미지 3개 중 3개
    • Remove the ten 8.9mm Tri-point Y1 screws hidden underneath square stickers.
    • Lift up the back plate.
    • The back plate is still connected by a cable to the motherboard.
  2. Nintendo Wii U GamePad Directional Pad Buttons Replacement: 2 단계, 이미지 2개 중 1개 Nintendo Wii U GamePad Directional Pad Buttons Replacement: 2 단계, 이미지 2개 중 2개
    • Unplug the connector that connects the back plate to the motherboard.
    • Remove the back panel.
  3. Nintendo Wii U GamePad Directional Pad Buttons Replacement, Analog Stick: 3 단계, 이미지 2개 중 1개 Nintendo Wii U GamePad Directional Pad Buttons Replacement, Analog Stick: 3 단계, 이미지 2개 중 2개
    • Take out the left and right shoulder buttons in the upper corners.
    • Remove the ZR and ZL trigger buttons by lifting up and sliding outward.
  4. Nintendo Wii U GamePad Directional Pad Buttons Replacement: 4 단계, 이미지 2개 중 1개 Nintendo Wii U GamePad Directional Pad Buttons Replacement: 4 단계, 이미지 2개 중 2개
    • Remove the top rubber cover by pulling it off of its mounts to access one of the mounting screws.
    • Remove the four 5.2mm Phillips #0 screws.
  5. Nintendo Wii U GamePad Directional Pad Buttons Replacement: 5 단계, 이미지 2개 중 1개 Nintendo Wii U GamePad Directional Pad Buttons Replacement: 5 단계, 이미지 2개 중 2개
    • Use a spudger to lift the tab which releases the blue ribbon cable.
    • Remove the analog stick and button cover.
  6. Nintendo Wii U GamePad Directional Pad Buttons Replacement: 6 단계, 이미지 1개 중 1개
    • Use your thumb and push the connector towards the rightmost edge to disconnect the analog stick cable connector.
  7. Nintendo Wii U GamePad Directional Pad Buttons Replacement: 7 단계, 이미지 2개 중 1개 Nintendo Wii U GamePad Directional Pad Buttons Replacement: 7 단계, 이미지 2개 중 2개
    • Remove the two 9.0mm Tri-point Y0 screws.
    • Lift out the analog stick.
  8. Nintendo Wii U GamePad Directional Pad Buttons Replacement, Directional Pad Buttons: 8 단계, 이미지 2개 중 1개 Nintendo Wii U GamePad Directional Pad Buttons Replacement, Directional Pad Buttons: 8 단계, 이미지 2개 중 2개
    • Lift up and remove the rubber cover for the directional pad.
    • Remove the directional pad buttons.
결론
다른 12명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Kim Arre
회원 가입일: 01/11/13
5,460 평판
안내서 8개를 작성함
Cal Poly, Team 17-20, Forte Winter 2013 Cal Poly, Team 17-20, Forte Winter 2013 회원
CPSU-FORTE-W13S17G20
5 회원들
안내서 41개를 작성함
1가이드 댓글
Where can you find the blue ribbon mentioned in step 5, for the buttons at?
Eric - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 17
지난 30일: 119
전체 시간: 22,610
