주요 콘텐츠로 건너뛰기
Nintendo Wii U Gamepad ZL and ZR Triggers Replacement
필요한 것
  1. Nintendo Wii U Gamepad ZL and ZR Triggers Replacement, ZL and ZR Triggers: 1 단계, 이미지 3개 중 1개 Nintendo Wii U Gamepad ZL and ZR Triggers Replacement, ZL and ZR Triggers: 1 단계, 이미지 3개 중 2개 Nintendo Wii U Gamepad ZL and ZR Triggers Replacement, ZL and ZR Triggers: 1 단계, 이미지 3개 중 3개
    • Place the Wii U gamepad on a soft surface or use minimal force to avoid placing pressure on the joysticks and screen.
    • Loosen the two 4.7 mm screws located on the bottom using a Phillips #00 screwdriver.
    • Unlatch and remove the cover to unveil the battery.
  2. Nintendo Wii U Gamepad ZL and ZR Triggers Replacement: 2 단계, 이미지 2개 중 1개 Nintendo Wii U Gamepad ZL and ZR Triggers Replacement: 2 단계, 이미지 2개 중 2개
    • Grab the battery by the sides and gently remove it from the slot.
    • Gently press down on the wire's latch to disconnect the battery.
    • Remove the battery and set it aside.
  3. Nintendo Wii U Gamepad ZL and ZR Triggers Replacement: 3 단계, 이미지 2개 중 1개 Nintendo Wii U Gamepad ZL and ZR Triggers Replacement: 3 단계, 이미지 2개 중 2개
    • Gently slide your fingernails under the ten rubber pads to remove them and reveal the hidden screws.
    • A thin tool or pin can be used to remove the plastic covers.
  4. Nintendo Wii U Gamepad ZL and ZR Triggers Replacement: 4 단계, 이미지 3개 중 1개 Nintendo Wii U Gamepad ZL and ZR Triggers Replacement: 4 단계, 이미지 3개 중 2개 Nintendo Wii U Gamepad ZL and ZR Triggers Replacement: 4 단계, 이미지 3개 중 3개
    • Remove the ten 8.9 mm Tri-wing Y1 backplate screws.
    • Gently open the backplate by lifting it from the bottom to unveil the internals.
    • Gently remove the plastic wire connecting the backplate to the board.
    • Do not rip open the backplate to avoid damaging the Gamepad.
  5. Nintendo Wii U Gamepad ZL and ZR Triggers Replacement: 5 단계, 이미지 3개 중 1개 Nintendo Wii U Gamepad ZL and ZR Triggers Replacement: 5 단계, 이미지 3개 중 2개 Nintendo Wii U Gamepad ZL and ZR Triggers Replacement: 5 단계, 이미지 3개 중 3개
    • Gently lift and slide the ZL and ZR triggers off to remove them from the slot.
  6. Nintendo Wii U Gamepad ZL and ZR Triggers Replacement: 6 단계, 이미지 3개 중 1개 Nintendo Wii U Gamepad ZL and ZR Triggers Replacement: 6 단계, 이미지 3개 중 2개 Nintendo Wii U Gamepad ZL and ZR Triggers Replacement: 6 단계, 이미지 3개 중 3개
    • Insert the new triggers by gently sliding them into the ZL and ZR spots respectively.
    • Continue to reassembling the Gamepad.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Karim Karam
회원 가입일: 01/13/25
160 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 12
지난 30일: 72
전체 시간: 495
