주요 콘텐츠로 건너뛰기
Nintendo Wii U Pro Controller D-Pad Replacement
필요한 것
  1. Nintendo Wii U Pro Controller D-Pad Replacement, Battery: 1 단계, 이미지 1/1
    • Turn the controller over to reveal the battery cover.
    • Use the J000 screwdriver to remove the screw that secures the battery cover.
  2. Nintendo Wii U Pro Controller D-Pad Replacement: 2 단계, 이미지 1/2 Nintendo Wii U Pro Controller D-Pad Replacement: 2 단계, 이미지 2/2
    • Remove the battery from the controller by inserting the plastic spudger into the small gap on the bottom right of the battery.
    • Use the spudger as a lever to pry up and remove the battery from the compartment.
  3. Nintendo Wii U Pro Controller D-Pad Replacement, Joystick: 3 단계, 이미지 1/1
    • Remove the eight 5.5 mm Y0 screws.
  4. Nintendo Wii U Pro Controller D-Pad Replacement: 4 단계, 이미지 1/2 Nintendo Wii U Pro Controller D-Pad Replacement: 4 단계, 이미지 2/2
    • Now that you have removed all of the screws, carefully separate and remove the bottom half of the controller shell from the top half.
    • If you feel any resistance when pulling the shells apart, use a spudger to separate the left and right trigger contact assemblies from the bottom shell.
  5. Nintendo Wii U Pro Controller D-Pad Replacement: 5 단계, 이미지 1/1
    • Move the right trigger and sensor out of the way.
    • Remove the 4 mm JIS #0 screw.
  6. Nintendo Wii U Pro Controller D-Pad Replacement: 6 단계, 이미지 1/1
    • Move the left trigger and sensor out of the way.
  7. Nintendo Wii U Pro Controller D-Pad Replacement: 7 단계, 이미지 1/1
    • Remove the joysticks and motherboard from the controller’s shell.
  8. Nintendo Wii U Pro Controller D-Pad Replacement: 8 단계, 이미지 1/1
    • Carefully pull the rubber thumbsticks off of the electronic bearings to remove the joysticks.
  9. Nintendo Wii U Pro Controller D-Pad Replacement, D-Pad: 9 단계, 이미지 1/1
    • Locate the two 4 mm motherboard screws, shown circled in red, with the J0 screwdriver.
  10. Nintendo Wii U Pro Controller D-Pad Replacement: 10 단계, 이미지 1/1
    • Remove the motherboard and connected components. The rubber pad of the D-Pad is indicated in the image by the red arrow.
  11. Nintendo Wii U Pro Controller D-Pad Replacement: 11 단계, 이미지 1/1
    • Remove the rubber pad and D-Pad button. The D-Pad can be replaced by the new D-Pad or be cleaned to improve condition.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Jesse Burton
회원 가입일: 09/17/15
586 평판
안내서 3개 작성하였습니다
IUPUI, Team 2-2, Harley Fall 2015 IUPUI, Team 2-2, Harley Fall 2015 회원
IUPUI-HARLEY-F15S2G2
4 회원들
안내서 13개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 10
30일 전: 45
전체 시간: 4,428
