주요 콘텐츠로 건너뛰기
Nintendo Wii U Pro Controller Joystick Replacement
필요한 것
  1. Nintendo Wii U Pro Controller Joystick Replacement, Battery: 1 단계, 이미지 1/1
    • Turn the controller over to reveal the battery cover.
    • Use the J000 screwdriver to remove the screw that secures the battery cover.
  2. Nintendo Wii U Pro Controller Joystick Replacement: 2 단계, 이미지 1/2 Nintendo Wii U Pro Controller Joystick Replacement: 2 단계, 이미지 2/2
    • Remove the battery from the controller by inserting the plastic spudger into the small gap on the bottom right of the battery.
    • Use the spudger as a lever to pry up and remove the battery from the compartment.
  3. Nintendo Wii U Pro Controller Joystick Replacement, Joystick: 3 단계, 이미지 1/1
    • Remove the eight 5.5 mm Y0 screws.
  4. Nintendo Wii U Pro Controller Joystick Replacement: 4 단계, 이미지 1/2 Nintendo Wii U Pro Controller Joystick Replacement: 4 단계, 이미지 2/2
    • Now that you have removed all of the screws, carefully separate and remove the bottom half of the controller shell from the top half.
    • If you feel any resistance when pulling the shells apart, use a spudger to separate the left and right trigger contact assemblies from the bottom shell.
  5. Nintendo Wii U Pro Controller Joystick Replacement: 5 단계, 이미지 1/1
    • Move the right trigger and sensor out of the way.
    • Remove the 4 mm JIS #0 screw.
  6. Nintendo Wii U Pro Controller Joystick Replacement: 6 단계, 이미지 1/1
    • Move the left trigger and sensor out of the way.
  7. Nintendo Wii U Pro Controller Joystick Replacement: 7 단계, 이미지 1/1
    • Remove the joysticks and motherboard from the controller’s shell.
  8. Nintendo Wii U Pro Controller Joystick Replacement: 8 단계, 이미지 1/1
    • Carefully pull the rubber thumbsticks off of the electronic bearings to remove the joysticks.
결승점
다른 9명이 해당 안내서를 완성하였습니다.
Jesse Burton
회원 가입일: 09/17/15
586 평판
안내서 3개 작성하였습니다
IUPUI, Team 2-2, Harley Fall 2015 IUPUI, Team 2-2, Harley Fall 2015 회원
IUPUI-HARLEY-F15S2G2
4 회원들
안내서 13개 작성하였습니다
댓글 한 개
Where can I buy those Nintendo wii u pro controller analog joystick prints? I can only find them for the wii u Gamepad on ebay.
Thx for a good guide!
Simon Denmark
Simon Martin Sørensen - 답글
댓글 쓰기
조회 통계:
24 시간 전: 5
7일 전: 16
30일 전: 124
전체 시간: 9,279
