소개
Use this guide to replace joysticks on your Wii U Pro controller.
Joysticks allow you to control the Wii U console and the game being played. If the joysticks are sticking, drifting, or loose this can impact gameplay and overall usability. This issue may occur due to overuse, incorrect calibration settings, and/or faulty parts.
Before using this guide, inspect the joysticks for debris and/or buildup and clear them using compressed air and alcohol wipes, then recalibrate the controller by resetting the joysticks to a neutral position.
Make sure the controller is completely powered off and disconnected from any external power source before you begin.
부품
지정된 부품이 없습니다.
Turn the controller over to reveal the battery cover.
Use the J000 screwdriver to remove the screw that secures the battery cover.
다른 6명이 해당 안내서를 완성하였습니다.
댓글 한 개
Where can I buy those Nintendo wii u pro controller analog joystick prints? I can only find them for the wii u Gamepad on ebay.
Thx for a good guide!
Simon Denmark
