주요 콘텐츠로 건너뛰기
Nintendo Wii U Pro Controller ZL and ZR Button Replacement
필요한 것
  1. Nintendo Wii U Pro Controller ZL and ZR Button Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Turn the controller over to reveal the battery cover.
    • Use the J000 screwdriver to remove the screw that secures the battery cover.
  2. Nintendo Wii U Pro Controller ZL and ZR Button Replacement: 2 단계, 이미지 2개 중 1개 Nintendo Wii U Pro Controller ZL and ZR Button Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the battery from the controller by inserting the plastic spudger into the small gap on the bottom right of the battery.
    • Use the spudger as a lever to pry up and remove the battery from the compartment.
  3. Nintendo Wii U Pro Controller ZL and ZR Button Replacement, ZL and ZR Buttons: 3 단계, 이미지 1개 중 1개
    • Once the battery has been removed, we will remove the 4 screws in the battery compartment and then the 4 screws around the back of the case. These 8 screws use the Y0 bit. Each of these screws are 5.5 mm.
    • The four screws on the outside are extremely deep into the casing, and the holes are pretty small. You will need to use a 4 mm driver bit extension to reach these screws.
  4. Nintendo Wii U Pro Controller ZL and ZR Button Replacement: 4 단계, 이미지 1개 중 1개
    • Once all of the screws are removed, simply use one hand to hold the front panel in place and lift up on the back panel to remove it. Place the back panel so the insides are facing up towards you.
  5. Nintendo Wii U Pro Controller ZL and ZR Button Replacement: 5 단계, 이미지 2개 중 1개 Nintendo Wii U Pro Controller ZL and ZR Button Replacement: 5 단계, 이미지 2개 중 2개
    • Locate the two triggers (ZL and ZR) and pop them up and out by pressing on them from the outside.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Jesse Burton
회원 가입일: 09/17/15
604 평판
안내서 3개를 작성함
IUPUI, Team 2-2, Harley Fall 2015 IUPUI, Team 2-2, Harley Fall 2015 회원
IUPUI-HARLEY-F15S2G2
4 회원들
안내서 15개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 24
전체 시간: 5,291
