주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nintendo Wii Wi-Fi Board Replacement
필요한 것
  1. Nintendo Wii Wi-Fi Board Replacement, Faceplate: 1 단계, 이미지 2개 중 1개 Nintendo Wii Wi-Fi Board Replacement, Faceplate: 1 단계, 이미지 2개 중 2개
    • Use a metal spudger to remove the white plastic screw covers stuck to the lower case near the front of the Wii.
  2. Nintendo Wii Wi-Fi Board Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the two 8.3 mm Tri-Point screws hidden under the covers you just removed.
  3. Nintendo Wii Wi-Fi Board Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the single 5.9 mm Phillips screw under the controller port door nearest the faceplate.
  4. Nintendo Wii Wi-Fi Board Replacement: 4 단계, 이미지 1개 중 1개
    • Use a metal spudger to remove the rubber foot stuck to the side of the Wii near the DVD drive opening.
  5. Nintendo Wii Wi-Fi Board Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the single 5.9 mm Phillips screw hidden under the foot you just removed.
  6. Nintendo Wii Wi-Fi Board Replacement: 6 단계, 이미지 2개 중 1개 Nintendo Wii Wi-Fi Board Replacement: 6 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Carefully pull the faceplate away from the front of the Wii.
    • Use a pair of tweezers to disconnect the LED cable's plastic connector from the motherboard.
    • Remove the faceplate.
  7. Nintendo Wii Wi-Fi Board Replacement, Outer Case: 7 단계, 이미지 3개 중 1개 Nintendo Wii Wi-Fi Board Replacement, Outer Case: 7 단계, 이미지 3개 중 2개 Nintendo Wii Wi-Fi Board Replacement, Outer Case: 7 단계, 이미지 3개 중 3개
    • Open the controller port cover until it is perpendicular to the black controller port bezel.
    • Pull the controller port cover straight up to release it from the outer case.
    • Repeat this procedure for the memory card port cover.
  8. Nintendo Wii Wi-Fi Board Replacement: 8 단계, 이미지 2개 중 1개 Nintendo Wii Wi-Fi Board Replacement: 8 단계, 이미지 2개 중 2개
    • Remove the two remaining 4.1 mm Phillips screws along the top edge of the black plastic controller port bezel.
    • Lift the bezel from the long edge furthest away from the controller ports and remove it from the Wii.
  9. Nintendo Wii Wi-Fi Board Replacement: 9 단계, 이미지 1개 중 1개
    • Remove the two 5 mm Phillips screws above the controller ports.
  10. Nintendo Wii Wi-Fi Board Replacement: 10 단계, 이미지 1개 중 1개
    • Use a metal spudger to remove the three highlighted screw covers stuck to the side of the Wii.
  11. Nintendo Wii Wi-Fi Board Replacement: 11 단계, 이미지 1개 중 1개
    • Remove the following screws:
    • Two 5 mm Phillips screws
    • One 8.2 mm Tri-Point screw
  12. Nintendo Wii Wi-Fi Board Replacement: 12 단계, 이미지 1개 중 1개
    • Use a metal spudger to remove the two rubber feet stuck to the bottom face of the Wii near the rear ports.
  13. Nintendo Wii Wi-Fi Board Replacement: 13 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    iFixit Precision 4 mm Screwdriver Bit
    $2.99
    • Remove the two 8.2 mm Tri-Point screws hidden under the feet you just removed.
    • You may use a 4 mm hex nut driver to extend your bit into the recesses and reach the screws.
  14. Nintendo Wii Wi-Fi Board Replacement: 14 단계, 이미지 1개 중 1개
    • Lift the outer case straight up off the body of the Wii.
  15. Nintendo Wii Wi-Fi Board Replacement, DVD Drive: 15 단계, 이미지 2개 중 1개 Nintendo Wii Wi-Fi Board Replacement, DVD Drive: 15 단계, 이미지 2개 중 2개
    • Remove the small Phillips screw securing the battery door to the bottom panel.
    • This screw is captive to the battery door.
    • Pull the battery door out of the Wii.
    • The system time will be reset once you remove the battery door.
    • This is a good time to change the CR2032 battery if it hasn't been changed recently.
  16. Nintendo Wii Wi-Fi Board Replacement: 16 단계, 이미지 1개 중 1개
    • Remove the 8.2 mm Tri-Point screw that was hidden beneath the battery door.
  17. Nintendo Wii Wi-Fi Board Replacement: 17 단계, 이미지 1개 중 1개
    • Remove the two 8.2 mm Tri-Point screws securing the DVD drive shield near the controller ports.
  18. Nintendo Wii Wi-Fi Board Replacement: 18 단계, 이미지 1개 중 1개
    • Be cautious as you remove the DVD shield, the edges are sharp and could cut you
    • Lift the DVD drive shield upward and remove it from the Wii.
  19. Nintendo Wii Wi-Fi Board Replacement: 19 단계, 이미지 1개 중 1개
    • Remove the four 9 mm Phillips screws securing the DVD drive to the bottom panel.
  20. Nintendo Wii Wi-Fi Board Replacement: 20 단계, 이미지 1개 중 1개
    • Lift the side of the DVD drive opposite the controller ports enough to access the cables on its bottom face.
    • Carefully pull the DVD drive power cable out from under the plastic shroud near the heat sink.
  21. Nintendo Wii Wi-Fi Board Replacement: 21 단계, 이미지 1개 중 1개
    • Pull the DVD drive power cable away from its socket on the DVD drive.
  22. Nintendo Wii Wi-Fi Board Replacement: 22 단계, 이미지 2개 중 1개 Nintendo Wii Wi-Fi Board Replacement: 22 단계, 이미지 2개 중 2개
    • Use your fingernail to flip up the retaining flap on the DVD drive ribbon cable socket.
    • Be sure you are prying up on the retaining flap, not the socket itself.
    • Pull the DVD drive ribbon cable out of its socket.
    • Remove the DVD drive from the Wii.
  23. Nintendo Wii Wi-Fi Board Replacement, Motherboard Cover: 23 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Use a pair of tweezers to lift the fan connector up and out of its socket on the logic board.
    • Be sure your tweezers are clamped down on the fan connector, not the socket on the motherboard.
  24. Nintendo Wii Wi-Fi Board Replacement: 24 단계, 이미지 2개 중 1개 Nintendo Wii Wi-Fi Board Replacement: 24 단계, 이미지 2개 중 2개
    • Remove the two 10 mm Phillips screws securing the fan to the fan shroud.
    • Remove the fan from the Wii.
  25. Nintendo Wii Wi-Fi Board Replacement: 25 단계, 이미지 2개 중 1개 Nintendo Wii Wi-Fi Board Replacement: 25 단계, 이미지 2개 중 2개
    • Use the tip of a spudger or another fine-pointed tool to carefully pry one of the black plastic retaining fingers attached to the fan shroud away from the Wi-Fi antenna board.
    • Lift the Wi-Fi antenna out of the fan shroud.
  26. Nintendo Wii Wi-Fi Board Replacement: 26 단계, 이미지 1개 중 1개
    • Remove the single 10 mm Phillips screw securing the second Wi-Fi antenna to the top of the fan shroud.
  27. Nintendo Wii Wi-Fi Board Replacement: 27 단계, 이미지 1개 중 1개
    • Remove the two pieces of tape securing the second Wi-Fi antenna cable to the plastic bracket near the heat sink.
  28. Nintendo Wii Wi-Fi Board Replacement: 28 단계, 이미지 1개 중 1개
    • Carefully de-route both antennas from the frame of the Wii and lay them aside.
  29. Nintendo Wii Wi-Fi Board Replacement: 29 단계, 이미지 2개 중 1개 Nintendo Wii Wi-Fi Board Replacement: 29 단계, 이미지 2개 중 2개
    • Remove the three 10 mm Phillips screws securing the fan shroud to the Wii.
    • Lift the fan shroud off the heat sink and remove it from the Wii.
  30. Nintendo Wii Wi-Fi Board Replacement: 30 단계, 이미지 3개 중 1개 Nintendo Wii Wi-Fi Board Replacement: 30 단계, 이미지 3개 중 2개 Nintendo Wii Wi-Fi Board Replacement: 30 단계, 이미지 3개 중 3개
    • Remove the following six screws securing the EMI fingers to the bottom panel:
    • Four 7 mm Phillips screws
    • Two 11.3 mm Phillips screws
    • Remove both sets of EMI fingers from the Wii.
  31. Nintendo Wii Wi-Fi Board Replacement: 31 단계, 이미지 2개 중 1개 Nintendo Wii Wi-Fi Board Replacement: 31 단계, 이미지 2개 중 2개
    • Remove the following three screws:
    • One 7 mm Phillips screw
    • Two 10 mm Phillips screws
    • Lift the bracket out of the Wii.
  32. Nintendo Wii Wi-Fi Board Replacement: 32 단계, 이미지 3개 중 1개 Nintendo Wii Wi-Fi Board Replacement: 32 단계, 이미지 3개 중 2개 Nintendo Wii Wi-Fi Board Replacement: 32 단계, 이미지 3개 중 3개
    • Remove the three 10 mm Phillips screws securing the black bracket to the bottom panel near the front of the Wii.
    • Slightly lift the bracket and use your other hand to pull the retaining clip away from where the Wi-Fi antennas enter the motherboard sheild.
    • Remove the bracket from the Wii.
    • Be sure not to lose the small square nut loosely held by the black plastic bracket.
  33. Nintendo Wii Wi-Fi Board Replacement: 33 단계, 이미지 1개 중 1개
    • Remove the nine remaining 7 mm Phillips screws securing the motherboard cover to the bottom panel.
  34. Nintendo Wii Wi-Fi Board Replacement: 34 단계, 이미지 1개 중 1개
    • Carefully lift the motherboard cover off the motherboard, minding any cables that may get caught.
    • On some models, a thermal pad for the wireless chip is attached to the underside of the motherboard cover. Be sure to replace it when reassembling.
  35. Nintendo Wii Wi-Fi Board Replacement, Wi-Fi Antennas: 35 단계, 이미지 1개 중 1개
    • Lift the side of the Wi-Fi board furthest away from the heat sink and lift it out of its socket on the motherboard, being careful not to put too much sideways force on the connector.
  36. Nintendo Wii Wi-Fi Board Replacement: 36 단계, 이미지 1개 중 1개
    • Use the flat end of a spudger to pry both antenna connectors off their sockets on the Wi-Fi board.
  37. Nintendo Wii Wi-Fi Board Replacement, Wi-Fi Board: 37 단계, 이미지 1개 중 1개
    • Wi-Fi board remains.
결론
다른 10명이 해당 안내서를 완성하였습니다.
5가이드 댓글
I really love the great step by step manuals.
Daniel Rourke - 답글 공유
The final photo appears to be the Bluetooth board and NOT the WiFi board (which matches the board seen on the Bluetooth replacement how-to: Nintendo Wii Bluetooth Board Replacement). The ifixit purchase page for the correct image for the WiFi board can be seen here: Nintendo Wii Wi-Fi Board
CliffyPop - 답글 공유
The Bluetooth card and the wifi card have the same the look amd even the model numbers match except fonthe the last digit. The wifi card will be
Model:JH27H003 = wifi card
Model:JH27H002 = Bluetooth.
I have both cards in front of me taken out of my broken nintendo wii as I write this. And incase anyone is unsure you can measure them to confirm. Wifi card is 1 1/2 in and the bluetooth is 1 inch. Hope this helps anyone that might have difficulties with them like i did till I dod a brief Google search.
***NOTE: Im just giving an examples of the ones that I pulled from mine there are other ones that Nintendo used so be sure to make sure that you pull it out and see the outline of where the Wi-Fi adapter was it's the exact size it should be on the outline
Richard Denny - 답글 공유
very nice but how do you know if this board is not working? I have 5 wii systems with many remotes and they all do the same thing. remote control shows hand for two seconds then goes blank. kman10kman@gmail.com
Lawrence Kaminski - 답글 공유
Have 4 wii systems all doing the same thing looks like sync is connecting but hand disappears after a few seconds is the wifi board going bad or is it something else?
댓글 쓰기
조회 통계:
지난 24시간: 10
지난 7일: 62
지난 30일: 322
전체 시간: 34,413
