주요 콘텐츠로 건너뛰기
Nintendo Wii mini Fan Replacement
필요한 것
  1. Nintendo Wii mini Fan Replacement, Unscrew the Bottom: 1 단계, 이미지 1/2 Nintendo Wii mini Fan Replacement, Unscrew the Bottom: 1 단계, 이미지 2/2
    • Remove the two rubber feet at the back of the console to reveal the hidden screws.
    • Remove the four 6mm Phillips #0 screws.
  2. Nintendo Wii mini Fan Replacement, Remove the Cover: 2 단계, 이미지 1/3 Nintendo Wii mini Fan Replacement, Remove the Cover: 2 단계, 이미지 2/3 Nintendo Wii mini Fan Replacement, Remove the Cover: 2 단계, 이미지 3/3
    • Turn the Wii mini right-side up. Then run a plastic opening tool around the middle edge of the console to loosen the top piece.
    • Gently lift the top piece of the console and set it aside.
  3. Nintendo Wii mini Fan Replacement, Unscrew the Fan: 3 단계, 이미지 1/2 Nintendo Wii mini Fan Replacement, Unscrew the Fan: 3 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Turn the Wii mini around so that the back of the device is facing you.
    • Using a Phillips #0 Screwdriver, unscrew the two 6mm screws on either side of the fan piece.
    • You may need to use tweezers to pull out the screws once they are loosened.
  4. Nintendo Wii mini Fan Replacement, Detach the Fan Connector: 4 단계, 이미지 1/3 Nintendo Wii mini Fan Replacement, Detach the Fan Connector: 4 단계, 이미지 2/3 Nintendo Wii mini Fan Replacement, Detach the Fan Connector: 4 단계, 이미지 3/3
    • Using your fingers, gently pull the top of the pin connector straight up to detach the fan from the console.
    • Do not wiggle the connector or cable while removing. This may cause the connector to come loose
    • Remove the fan piece and set it aside.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Kristin Anderson
회원 가입일: 01/23/15
963 평판
안내서 5개 작성하였습니다
UWT Liner: Group 5 UWT Liner: Group 5 회원
Community
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 18
전체 시간: 1,291
