소개
Use this guide to replace the motherboard in your Nintendo Wii mini.
Turn the Wii mini upside down.
Remove the two rubber feet at the back of the console to reveal the hidden screws.
Remove the four 6mm Phillips #0 screws.
Using your fingers, slide out the blue ribbon cable from the the top of the power board.
Using a Phillips #0 Screwdriver, unscrew the two 4mm screws at the top and bottom of the power board.
Using a Phillips #0 Screwdriver, unscrew the 6mm screw at the top of the black tray.
다른 4명이 해당 안내서를 완성하였습니다.
댓글 한 개
Can you fit a Wii Motherboard inside this casing, and use the dvd drive, if so I have a few wiis with broken DVD drives I would like to repair and this would be a cheap solution.
