주요 콘텐츠로 건너뛰기
Nishiki Aero II Front Inner Tube Replacement
필요한 것
  1. Nishiki Aero II Front Inner Tube Replacement, Removing Road Bike Front Wheel: 1 단계, 이미지 1개 중 1개
    • Turn the bike upside down.
  2. Nishiki Aero II Front Inner Tube Replacement: 2 단계, 이미지 1개 중 1개
    • Use a wrench to loosen the nut holding the wheel's axle on one side.
    • Once it's loose enough, continue removing the nut with your hand.
  3. Nishiki Aero II Front Inner Tube Replacement: 3 단계, 이미지 2개 중 1개 Nishiki Aero II Front Inner Tube Replacement: 3 단계, 이미지 2개 중 2개
    • After removing the nut, also remove the washer under it.
    • Keep note of how the washer has a small appendage that locks into a slot in the fork.
  4. Nishiki Aero II Front Inner Tube Replacement: 4 단계, 이미지 1개 중 1개
    • Follow the previous steps for the opposite side.
  5. Nishiki Aero II Front Inner Tube Replacement: 5 단계, 이미지 1개 중 1개
    • Lift the wheel up from the fork.
  6. Nishiki Aero II Front Inner Tube Replacement, Nishiki Aero II Tire Removal: 6 단계, 이미지 2개 중 1개 Nishiki Aero II Front Inner Tube Replacement, Nishiki Aero II Tire Removal: 6 단계, 이미지 2개 중 2개
    • Unscrew the cap from the air valve.
    • Release the tire's air by pressing a thin object on the center pin of the valve.
    • A hex wrench or any blunt object can be used.
  7. Nishiki Aero II Front Inner Tube Replacement: 7 단계, 이미지 3개 중 1개 Nishiki Aero II Front Inner Tube Replacement: 7 단계, 이미지 3개 중 2개 Nishiki Aero II Front Inner Tube Replacement: 7 단계, 이미지 3개 중 3개
    • Wedge a tire lever between the tire and the rim. Grab the tire with the lever's inward scoop.
    • Grab the tire's edge with the lever and pull it back to scoop the tire from the rim.
    • Keep the tire lever anchored on a spoke with the notch on the lever's opposite end.
  8. Nishiki Aero II Front Inner Tube Replacement: 8 단계, 이미지 2개 중 1개 Nishiki Aero II Front Inner Tube Replacement: 8 단계, 이미지 2개 중 2개
    • Repeat with an additional tire lever five inches away from the other.
  9. Nishiki Aero II Front Inner Tube Replacement: 9 단계, 이미지 3개 중 1개 Nishiki Aero II Front Inner Tube Replacement: 9 단계, 이미지 3개 중 2개 Nishiki Aero II Front Inner Tube Replacement: 9 단계, 이미지 3개 중 3개
    • Repeat with a third tire lever farther around the tire.
    • Alternate lifting the second and third levers until the tire comes partway off.
  10. Nishiki Aero II Front Inner Tube Replacement: 10 단계, 이미지 3개 중 1개 Nishiki Aero II Front Inner Tube Replacement: 10 단계, 이미지 3개 중 2개 Nishiki Aero II Front Inner Tube Replacement: 10 단계, 이미지 3개 중 3개
    • Wedge the tire off of the other rim with the tire levers.
    • Pull the air valve from its hole in the rim to completely remove the tire.
  11. Nishiki Aero II Front Inner Tube Replacement, Front Inner Tube: 11 단계, 이미지 1개 중 1개
    • Now that the tire and tube are off of the rim, gently pull the tube out of the tire.
    • Be sure to pull gently, as the tube could potentially end up adhered to the inside of the tire.
  12. Nishiki Aero II Front Inner Tube Replacement: 12 단계, 이미지 1개 중 1개
    • Now, you've separated your tube, tire and rim.
    • To replace the tube, follow these instructions in reverse order using the new or patched tube.
    • Remember to inflate just a little bit of air into the tube before you try to install it, as that makes the process go much smoother.
결론
작성자
6다른 기여자 명과 함께
Tobias Elder
회원 가입일: 04/25/13
113 평판
안내서 7개를 작성함
Cal Poly, Team 21-53, Johann Spring 2013 Cal Poly, Team 21-53, Johann Spring 2013 회원
CPSU-JOHANN-S13S21G53
4 회원들
안내서 7개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 3
전체 시간: 1,539
