주요 콘텐츠로 건너뛰기
Nishiki Aero II Tire Removal
필요한 것
  1. Nishiki Aero II Tire Removal, Removing Road Bike Front Wheel: 1 단계, 이미지 1개 중 1개
    • Turn the bike upside down.
  2. Nishiki Aero II Tire Removal: 2 단계, 이미지 1개 중 1개
    • Use a wrench to loosen the nut holding the wheel's axle on one side.
    • Once it's loose enough, continue removing the nut with your hand.
  3. Nishiki Aero II Tire Removal: 3 단계, 이미지 2개 중 1개 Nishiki Aero II Tire Removal: 3 단계, 이미지 2개 중 2개
    • After removing the nut, also remove the washer under it.
    • Keep note of how the washer has a small appendage that locks into a slot in the fork.
  4. Nishiki Aero II Tire Removal: 4 단계, 이미지 1개 중 1개
    • Follow the previous steps for the opposite side.
  5. Nishiki Aero II Tire Removal: 5 단계, 이미지 1개 중 1개
    • Lift the wheel up from the fork.
  6. Nishiki Aero II Tire Removal, Nishiki Aero II Tire Removal: 6 단계, 이미지 2개 중 1개 Nishiki Aero II Tire Removal, Nishiki Aero II Tire Removal: 6 단계, 이미지 2개 중 2개
    • Unscrew the cap from the air valve.
    • Release the tire's air by pressing a thin object on the center pin of the valve.
    • A hex wrench or any blunt object can be used.
  7. Nishiki Aero II Tire Removal: 7 단계, 이미지 3개 중 1개 Nishiki Aero II Tire Removal: 7 단계, 이미지 3개 중 2개 Nishiki Aero II Tire Removal: 7 단계, 이미지 3개 중 3개
    • Wedge a tire lever between the tire and the rim. Grab the tire with the lever's inward scoop.
    • Grab the tire's edge with the lever and pull it back to scoop the tire from the rim.
    • Keep the tire lever anchored on a spoke with the notch on the lever's opposite end.
  8. Nishiki Aero II Tire Removal: 8 단계, 이미지 2개 중 1개 Nishiki Aero II Tire Removal: 8 단계, 이미지 2개 중 2개
    • Repeat with an additional tire lever five inches away from the other.
  9. Nishiki Aero II Tire Removal: 9 단계, 이미지 3개 중 1개 Nishiki Aero II Tire Removal: 9 단계, 이미지 3개 중 2개 Nishiki Aero II Tire Removal: 9 단계, 이미지 3개 중 3개
    • Repeat with a third tire lever farther around the tire.
    • Alternate lifting the second and third levers until the tire comes partway off.
  10. Nishiki Aero II Tire Removal: 10 단계, 이미지 3개 중 1개 Nishiki Aero II Tire Removal: 10 단계, 이미지 3개 중 2개 Nishiki Aero II Tire Removal: 10 단계, 이미지 3개 중 3개
    • Wedge the tire off of the other rim with the tire levers.
    • Pull the air valve from its hole in the rim to completely remove the tire.
결론
작성자
9다른 기여자 명과 함께
Tobias Elder
회원 가입일: 04/25/13
113 평판
안내서 7개를 작성함
Cal Poly, Team 21-53, Johann Spring 2013 Cal Poly, Team 21-53, Johann Spring 2013 회원
CPSU-JOHANN-S13S21G53
4 회원들
안내서 7개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 11
전체 시간: 1,329
