주요 콘텐츠로 건너뛰기
Niu Kqi2 Pro Scooter Thumb Throttle Replacement
필요한 것
  1. Niu Kqi2 Pro Scooter Thumb Throttle Replacement, Thumb Throttle: 1 단계, 이미지 1/2 Niu Kqi2 Pro Scooter Thumb Throttle Replacement, Thumb Throttle: 1 단계, 이미지 2/2
    • Use a spudger to slowly open the display cap.
  2. Niu Kqi2 Pro Scooter Thumb Throttle Replacement: 2 단계, 이미지 1/1
    • Remove the three screws using a Phillips screwdriver.
  3. Niu Kqi2 Pro Scooter Thumb Throttle Replacement: 3 단계, 이미지 1/2 Niu Kqi2 Pro Scooter Thumb Throttle Replacement: 3 단계, 이미지 2/2
    • Lift open the dashboard.
    • Unplug the wire connection that has the red, green, and black wires.
  4. Niu Kqi2 Pro Scooter Thumb Throttle Replacement: 4 단계, 이미지 1/3 Niu Kqi2 Pro Scooter Thumb Throttle Replacement: 4 단계, 이미지 2/3 Niu Kqi2 Pro Scooter Thumb Throttle Replacement: 4 단계, 이미지 3/3
    • Using the provided Hex wrench or your own Hex wrench, unscrew to loosen up the thumb throttle.
    • Remove the hand grip on the handle before removing your old thumb throttle.
  5. Niu Kqi2 Pro Scooter Thumb Throttle Replacement: 5 단계, 이미지 1/3 Niu Kqi2 Pro Scooter Thumb Throttle Replacement: 5 단계, 이미지 2/3 Niu Kqi2 Pro Scooter Thumb Throttle Replacement: 5 단계, 이미지 3/3
    • Insert the new thumb throttle back into the handle.
    • Feed the wiring into the interior of the dashboard bay.
    • Align the wire connection back, ensuring red goes with red, green goes with green, and black goes with black.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Jacky
회원 가입일: 10/25/23
175 평판
안내서 1개 작성함
CSU Los Angeles, Team 4-25, Kershman Fall 2023 CSU Los Angeles, Team 4-25, Kershman Fall 2023 회원
CSULA-KERSHMAN-F23S4G25
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 20
30일 전: 100
전체 시간: 507
