주요 콘텐츠로 건너뛰기
Nixon Mission Android Wear Battery Replacement
필요한 것
  1. Nixon Mission Android Wear Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Remove 4 4.5mm Phillips head screws from back side of watch using PH00 Phillips head.
  2. Nixon Mission Android Wear Battery Replacement: 2 단계, 이미지 1/1
    • Remove the back plate of watch.
  3. Nixon Mission Android Wear Battery Replacement: 3 단계, 이미지 1/1
    • Unclip 5 latches from motherboard using a plastic spudger.
  4. Nixon Mission Android Wear Battery Replacement: 4 단계, 이미지 1/1
    • Remove the 2 3.0mm screws from motherboard using PH00 Phillips head.
  5. Nixon Mission Android Wear Battery Replacement: 5 단계, 이미지 1/1
    • Carefully remove motherboard & internal screen.
  6. Nixon Mission Android Wear Battery Replacement: 6 단계, 이미지 1/1
    • Remove from the motherboard the connector with the four cables.
    • Pull the cables upward and the motherboard downward as shown in the picture.
  7. Nixon Mission Android Wear Battery Replacement: 7 단계, 이미지 1/1
    • Carefully remove the battery from the watch.
결론
다른 6명이 해당 안내서를 완성하였습니다.
Mauricio Ambrosio
회원 가입일: 11/07/17
191 평판
안내서 1개 작성함
IUPUI, Team S3-G2, Harley Fall 2017 IUPUI, Team S3-G2, Harley Fall 2017 회원
IUPUI-HARLEY-F17S3G2
3 회원들
안내서 3개 작성하였습니다
댓글 18개
Hi, would you be able to advise where to purchase a replacement battery?
Simon Seow - 답글
same here, where to purchase a replacement battery ?
peter.erdogyaraki - 답글
Thank you for your tuto.
But now, where I can purchase a new battery?
Thank you
COUTURIER - 답글
Hi! Anyone knows where to buy a new battery?
cristian.carvelli - 답글
After an extensive search there doesn't seem to be any info out there about battery size…..still
Jerry Jerry J - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 9
30일 전: 55
전체 시간: 6,440
