주요 콘텐츠로 건너뛰기
Nixon Mission Android Wear Motherboard Replacement
필요한 것
  1. Nixon Mission Android Wear Motherboard Replacement, Motherboard: 1 단계, 이미지 1/1
    • Unscrew 4 4.5mm Phillips head screws from the back of the device.
  2. Nixon Mission Android Wear Motherboard Replacement: 2 단계, 이미지 1/1
    • Remove back.
  3. Nixon Mission Android Wear Motherboard Replacement: 3 단계, 이미지 1/1
    • Unclip straps holding motherboard to screen using a spudger.
  4. Nixon Mission Android Wear Motherboard Replacement: 4 단계, 이미지 1/1
    • Unscrew 2 3.0mm Phillips head screws holding motherboard in place.
    • The other screw is hidden under the copper band on opposite side.
  5. Nixon Mission Android Wear Motherboard Replacement: 5 단계, 이미지 1/1
    • Remove the "core" of the device from case.
  6. Nixon Mission Android Wear Motherboard Replacement: 6 단계, 이미지 1/2 Nixon Mission Android Wear Motherboard Replacement: 6 단계, 이미지 2/2
    • Separate motherboard from screen and then clean or replace motherboard.
결론
Spencer Kolzow
회원 가입일: 11/07/17
170 평판
안내서 1개 작성함
IUPUI, Team S3-G2, Harley Fall 2017 IUPUI, Team S3-G2, Harley Fall 2017 회원
IUPUI-HARLEY-F17S3G2
3 회원들
안내서 3개 작성하였습니다
댓글 2개
Hello… where can i get the replacement motherboard???
Juan Pablo Balderrama - 답글
Is it still waterproof after you open it?
Smarty - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 779
