주요 콘텐츠로 건너뛰기
Nixon Watch Battery Replacement
필요한 것
  1. Nixon Watch Battery Replacement, Battery: 1 단계, 이미지 1/1
    • On a flat surface, use the PH00 screwdriver to remove the four screws from each corner, and set them in a safe place.
  2. Nixon Watch Battery Replacement: 2 단계, 이미지 1/2 Nixon Watch Battery Replacement: 2 단계, 이미지 2/2
    • Gently lift the back plate, and be careful to not damage the rubber gasket.
    • Use the 1.5 flathead, and carefully pry the battery out of the housing.
    • The battery is under spring tension and may fly out.
  3. Nixon Watch Battery Replacement: 4 단계, 이미지 1/2 Nixon Watch Battery Replacement: 4 단계, 이미지 2/2
    • Place the new battery in the battery housing. Ensure the positive side is facing up.
    • Ensure the battery is firmly seated. A faint click can be heard when it is firmly seated.
  4. Nixon Watch Battery Replacement: 5 단계, 이미지 1/2 Nixon Watch Battery Replacement: 5 단계, 이미지 2/2
    • Remove the rubber gasket from the back plate.
    • Use an alcohol wipe to clean the back plate and the watch housing where the gasket will sit. This will ensure a clean and an airtight fit.
  5. Nixon Watch Battery Replacement: 6 단계, 이미지 1/1
    • Seat the gasket back onto the back plate.
  6. Nixon Watch Battery Replacement: 7 단계, 이미지 1/1
    • Place the back plate back onto the main watch housing. Ensure the notch in the back plate is line up with the crown.
  7. Nixon Watch Battery Replacement: 8 단계, 이미지 1/1
    • Tighten screws in a star pattern until the backplate is tight.
  8. Nixon Watch Battery Replacement: 9 단계, 이미지 1/2 Nixon Watch Battery Replacement: 9 단계, 이미지 2/2
    • Pull the crown away from the watch and then turn the knob to set the time.
결론
You have successfully completed the battery
replacement on your wristwatch.
If the second hand doesn’t begin its rotation there is
one of two common problems. The first is that the
crown has not been properly engaged after the time
adjustment on steps 11 and 12. The second problem would be caused by a bad battery in which case you would need to repeat the steps over with another new battery.
If the problem persists contact the manufacturer for
further troubleshooting steps.
다른 20명이 해당 안내서를 완성하였습니다.
David Ratliff
회원 가입일: 06/24/15
260 평판
안내서 1개 작성함
Colorado Springs, Team 1-6, Mcmichael SU 2015 Colorado Springs, Team 1-6, Mcmichael SU 2015 회원
UCCS-MCMICHAEL-SU15S1G6
3 회원들
안내서 5개 작성하였습니다
댓글 12개
Works for also for my traser h3. Thank you!
marcrainerkamp - 답글
Good guide but one does not need to force out battery with a screwdriver. This is overkill. I would not recommend putting a screwdriver there because the gears are exposed in that area and a slip would damage them. Just a finger nail is needed to move a little spring cover slightly to let battery out. Same goes for putting battery back in. Fingers are all that are needed at that point.
Jesse Cox - 답글
I have a "Newton" model Nixon. All black and the watch hands are floating circles just to clarify. It seems to have a battery cover, almost like a strip, holding it in place. Is there a tutorial for this extra step?
Anthoney Rodriguez - 답글
Hey Anthony! were you able to find an answer to your question? I’m also looking to replace my Newton’s battery.
Yash K -
That is for the backlight module. It takes a 2016 battery. The battery seen in this tutorial powers the movement and sits underneath the backlight module.
Jerry Holloway -
댓글 쓰기
조회 통계:
24 시간 전: 5
7일 전: 61
30일 전: 305
전체 시간: 191,742
