주요 콘텐츠로 건너뛰기
Nobis NB07 Cameras Replacement
필요한 것
  1. Nobis NB07 Cameras Replacement, Opening the case: 1 단계, 이미지 1/1
    • Look towards the topside of the tablet, where the power button is located.
    • Insert a plastic opening tool in the crack between the two parts of the case.
    • Move it gently back and forth to open the case.
  2. Nobis NB07 Cameras Replacement: 2 단계, 이미지 1/3 Nobis NB07 Cameras Replacement: 2 단계, 이미지 2/3 Nobis NB07 Cameras Replacement: 2 단계, 이미지 3/3
    • With the plastic opening tool in the opening between the two sides of the case, slide the tool along the tablet's border to separate the two sides completely.
    • Be careful when you separate the two halves. Open the case from the opposite side of the camera, there is a cable connecting both halves of the case.
  3. Nobis NB07 Cameras Replacement, Replacing the battery: 3 단계, 이미지 1/3 Nobis NB07 Cameras Replacement, Replacing the battery: 3 단계, 이미지 2/3 Nobis NB07 Cameras Replacement, Replacing the battery: 3 단계, 이미지 3/3
    • Remove the tape holding the battery in place.
  4. Nobis NB07 Cameras Replacement: 4 단계, 이미지 1/3 Nobis NB07 Cameras Replacement: 4 단계, 이미지 2/3 Nobis NB07 Cameras Replacement: 4 단계, 이미지 3/3
    • Insert the flat end of the spudger tool in the crack beneath the battery.
    • Move the spudger tool carefully side to side to remove the glue that is holding the battery in place.
    • This is a soft battery, so a little bending is expected.
  5. Nobis NB07 Cameras Replacement: 5 단계, 이미지 1/1
    • After the battery is unglued, locate the cables that connect it to the motherboard.
    • Annotate where each color goes to make the reassembly easier.
  6. Nobis NB07 Cameras Replacement: 6 단계, 이미지 1/2 Nobis NB07 Cameras Replacement: 6 단계, 이미지 2/2
    • Desolder the cables with a soldering iron and use a desoldering braid to remove the solder.
    • Review the Ifixit soldering guide if you need help soldering.
    • You can now remove the battery.
  7. Nobis NB07 Cameras Replacement, Removing the cameras: 7 단계, 이미지 1/3 Nobis NB07 Cameras Replacement, Removing the cameras: 7 단계, 이미지 2/3 Nobis NB07 Cameras Replacement, Removing the cameras: 7 단계, 이미지 3/3
    • Remove the black tape covering the cameras power cable.
  8. Nobis NB07 Cameras Replacement: 8 단계, 이미지 1/2 Nobis NB07 Cameras Replacement: 8 단계, 이미지 2/2
    • Use the spudger tool to pry upwards the ZIF connector and release the power cable.
  9. Nobis NB07 Cameras Replacement: 9 단계, 이미지 1/3 Nobis NB07 Cameras Replacement: 9 단계, 이미지 2/3 Nobis NB07 Cameras Replacement: 9 단계, 이미지 3/3
    • With the power cable disconnected, the backside camera is free. However, both cameras are sequentially connected through the power cable; the front side camera is glued to the motherboard.
    • Using tweezers, carefully grab the front camera and twist slowly.
    • The camera should release easily, do not twist too hard.
    • You can now remove the cameras.
결론
Daniel Gomero
회원 가입일: 01/21/15
966 평판
안내서 5개 작성하였습니다
USF Tampa, Team 5-5, Brown Winter 2015 USF Tampa, Team 5-5, Brown Winter 2015 회원
USFT-BROWN-W15S5G5
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 121
