주요 콘텐츠로 건너뛰기
Noisy Percussion Massager Repair
필요한 것
  1. Noisy Percussion Massager Repair, Tools - #1 & #2 Phillips + thread locker: 1 단계, 이미지 1개 중 1개
    • Thread lock can be found at any hardware store.
  2. Noisy Percussion Massager Repair, Remove the rear cover: 2 단계, 이미지 2개 중 1개 Noisy Percussion Massager Repair, Remove the rear cover: 2 단계, 이미지 2개 중 2개
    • Twist counter-clockwise very snug. It only moves about 1/4 of an inch - the second picture shows the slide lock slots.
  3. Noisy Percussion Massager Repair, Remove Two Screws from Housing: 3 단계, 이미지 1개 중 1개
    • There were actually two rubber plugs covering the screws that I had to work out… Not hard.
  4. Noisy Percussion Massager Repair, Open It Up: 4 단계, 이미지 3개 중 1개 Noisy Percussion Massager Repair, Open It Up: 4 단계, 이미지 3개 중 2개 Noisy Percussion Massager Repair, Open It Up: 4 단계, 이미지 3개 중 3개
    • Case opens pretty easy but you can see there are two tabs toward the back of the case … if it sticks, a simple pinch might help you open it up.
  5. Noisy Percussion Massager Repair, Remove screw - Apply Thread Lock - Re install: 5 단계, 이미지 3개 중 1개 Noisy Percussion Massager Repair, Remove screw - Apply Thread Lock - Re install: 5 단계, 이미지 3개 중 2개 Noisy Percussion Massager Repair, Remove screw - Apply Thread Lock - Re install: 5 단계, 이미지 3개 중 3개
    • Insert wisdom here.
  6. Noisy Percussion Massager Repair, Re-assemble the case: 6 단계, 이미지 2개 중 1개 Noisy Percussion Massager Repair, Re-assemble the case: 6 단계, 이미지 2개 중 2개
    • Surprising how much noise a loose screw can cause.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
jtalbin
회원 가입일: 07/22/12
313 평판
안내서 2개를 작성함
댓글 9개
Where can I buy a gasket, for the Recovery Pro massager, that is worn out? Thank you.
Emilia Cirstea - 답글
We were unable to twist off the back on Step 2. Going to be returned to Costco since I can't fix it....
Richard DalCanto - 답글
I have model 11mg0811 it has no screws on the sides and I it will not twist off ,when it's on it makes a lot of noise,I don't want to return it to COSTCO IS THERE SOMEWHERE I CAN TAKE IT,
Ted - 답글
I've not found any shops locally that take these for repair. After looking at the pictures for the model 11MG0811 it appears that access to the inner workings is similar to an electronic toothbrush that uses a pinch/lock approach which can be quite a bit tougher.
jtalbin -
댓글 쓰기
조회 통계:
지난 24시간: 8
지난 7일: 25
지난 30일: 167
전체 시간: 11,712
