주요 콘텐츠로 건너뛰기
Nokero N222-Huron Colored Lens Replacement
  1. Nokero N222-Huron Colored Lens Replacement, Clear Cover: 1 단계, 이미지 1/1
    • Grasp the clear cover and the white housing and twist the cover counter-clockwise.
    • The lid may hold fast, but it will come off with some firm twisting.
  2. Nokero N222-Huron Colored Lens Replacement: 2 단계, 이미지 1/1
    • Lift the lid from the device
    • It may be helpful to use a spudger to pry under the lid if there is difficulty in getting a good grip on the smooth plastic.
  3. Nokero N222-Huron Colored Lens Replacement, Colored Lens: 3 단계, 이미지 1/3 Nokero N222-Huron Colored Lens Replacement, Colored Lens: 3 단계, 이미지 2/3 Nokero N222-Huron Colored Lens Replacement, Colored Lens: 3 단계, 이미지 3/3
    • Turn the lens until the slots line up with the retaining clips on the device.
    • Lift the lens off of the device. It should come off easily.
  4. Nokero N222-Huron Colored Lens Replacement: 4 단계, 이미지 1/2 Nokero N222-Huron Colored Lens Replacement: 4 단계, 이미지 2/2
    • When reinstalling the lends, line up the slots of the new lens with the retaining clips, and rotate the lens counter-clockwise.
    • You will hear an audible click when the lens is locked in place.
결론
To reassemble your device, follow the instructions for the first two steps in reverse order.
Vinny Capone
회원 가입일: 10/18/13
549 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team 2-4, Gulbrandsen Fall 2013 UMass Dartmouth, Team 2-4, Gulbrandsen Fall 2013 회원
UMASSD-GULBRANDSEN-F13S2G4
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 12
전체 시간: 245
