주요 콘텐츠로 건너뛰기
Nokero N222-Huron Mounting Technique
필요한 것
  1. Nokero N222-Huron Mounting Technique, Nokero N222-Huron Mounting Technique: 1 단계, 이미지 1/1
    • Place the mounting bracket in the desired location and mark the center location. This is where the screw will be placed.
    • It is optional to drill a pilot hole for the screw if splitting is a concern (usually for mounting in wood).
  2. Nokero N222-Huron Mounting Technique: 2 단계, 이미지 1/3 Nokero N222-Huron Mounting Technique: 2 단계, 이미지 2/3 Nokero N222-Huron Mounting Technique: 2 단계, 이미지 3/3
    • Place the screw through the bracket, as shown, and screw it into the marked or drilled location.
  3. Nokero N222-Huron Mounting Technique: 3 단계, 이미지 1/1
    • Make sure the bracket is facing in the desired direction before tightening the screw.
    • When the Nokero logo is facing forward, the light will pivot forward and backward.
  4. Nokero N222-Huron Mounting Technique: 4 단계, 이미지 1/3 Nokero N222-Huron Mounting Technique: 4 단계, 이미지 2/3 Nokero N222-Huron Mounting Technique: 4 단계, 이미지 3/3
    • Place the light in the bracket as shown and turn clockwise until it is secure.
결론
To remove or change the fixed mount for your device, follow these instructions in reverse order.
Vinny Capone
회원 가입일: 10/18/13
549 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team 2-4, Gulbrandsen Fall 2013 UMass Dartmouth, Team 2-4, Gulbrandsen Fall 2013 회원
UMASSD-GULBRANDSEN-F13S2G4
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 13
전체 시간: 203
