주요 콘텐츠로 건너뛰기
Nokero N222-Huron O-Ring Replacement
필요한 것
  1. Nokero N222-Huron O-Ring Replacement, Clear Cover: 1 단계, 이미지 1/1
    • Grasp the clear cover and the white housing and twist the cover counter-clockwise.
    • The lid may hold fast, but it will come off with some firm twisting.
  2. Nokero N222-Huron O-Ring Replacement: 2 단계, 이미지 1/1
    • Lift the lid from the device
    • It may be helpful to use a spudger to pry under the lid if there is difficulty in getting a good grip on the smooth plastic.
  3. Nokero N222-Huron O-Ring Replacement, O-Ring: 3 단계, 이미지 1/3 Nokero N222-Huron O-Ring Replacement, O-Ring: 3 단계, 이미지 2/3 Nokero N222-Huron O-Ring Replacement, O-Ring: 3 단계, 이미지 3/3
    • Using a plastic spudger, lift the o-ring from the lid
  4. Nokero N222-Huron O-Ring Replacement: 4 단계, 이미지 1/1
    • Gently stretch the new O-ring and place it in position on the clear cover. Make sure it is flush with the flange and not interfering with the locking threads
결론
Vinny Capone
회원 가입일: 10/18/13
549 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team 2-4, Gulbrandsen Fall 2013 UMass Dartmouth, Team 2-4, Gulbrandsen Fall 2013 회원
UMASSD-GULBRANDSEN-F13S2G4
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 13
전체 시간: 193
