주요 콘텐츠로 건너뛰기
Nokero N400 Back Cover Replacement
필요한 것
  1. Nokero N400 Back Cover Replacement, Remove Battery Cover: 1 단계, 이미지 1/3 Nokero N400 Back Cover Replacement, Remove Battery Cover: 1 단계, 이미지 2/3 Nokero N400 Back Cover Replacement, Remove Battery Cover: 1 단계, 이미지 3/3
    • Press down firmly to remove the battery cover and display battery.
    • Then remove the battery.
  2. Nokero N400 Back Cover Replacement, Unscrew Back Cover: 2 단계, 이미지 1/2 Nokero N400 Back Cover Replacement, Unscrew Back Cover: 2 단계, 이미지 2/2
    • Remove the 7mm Phillips #1 screw.
  3. Nokero N400 Back Cover Replacement, Pry Open Back Cover: 3 단계, 이미지 1/2 Nokero N400 Back Cover Replacement, Pry Open Back Cover: 3 단계, 이미지 2/2
    • Place the plastic opening tool in between the two plastic panels and slowly work your way around the device.
    • Unlatch the clips on the inside and pull device apart.
    • Some clips will break when forced open.
결론
Kasey Kolyno
회원 가입일: 01/20/15
125 평판
안내서 1개 작성함
USF Tampa, Team 19-2, Blackwell Winter 2015 USF Tampa, Team 19-2, Blackwell Winter 2015 회원
USFT-BLACKWELL-W15S19G2
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 130
