주요 콘텐츠로 건너뛰기
Nokero N400 LED Panel Replacement
필요한 것
  1. Nokero N400 LED Panel Replacement, Remove Battery Cover: 1 단계, 이미지 1/3 Nokero N400 LED Panel Replacement, Remove Battery Cover: 1 단계, 이미지 2/3 Nokero N400 LED Panel Replacement, Remove Battery Cover: 1 단계, 이미지 3/3
    • Press down firmly to remove the battery cover and display battery.
    • Then remove the battery.
  2. Nokero N400 LED Panel Replacement, Unscrew Back Cover: 2 단계, 이미지 1/2 Nokero N400 LED Panel Replacement, Unscrew Back Cover: 2 단계, 이미지 2/2
    • Remove the 7mm Phillips #1 screw.
  3. Nokero N400 LED Panel Replacement, Pry Open Back Cover: 3 단계, 이미지 1/2 Nokero N400 LED Panel Replacement, Pry Open Back Cover: 3 단계, 이미지 2/2
    • Place the plastic opening tool in between the two plastic panels and slowly work your way around the device.
    • Unlatch the clips on the inside and pull device apart.
    • Some clips will break when forced open.
  4. Nokero N400 LED Panel Replacement, Removing the LED Panel: 4 단계, 이미지 1/2 Nokero N400 LED Panel Replacement, Removing the LED Panel: 4 단계, 이미지 2/2
    • With the back cover of the device removed, lightly pull up on the LED assembly to lift it out of its housing.
    • The LED assembly will separate into three components; the light board, outer housing, and plastic lens.
  5. Nokero N400 LED Panel Replacement: 5 단계, 이미지 1/1
    • Set the outer housing and plastic lens aside.
    • Take a pair of pliers and cut the red and black wires connected to the light board.
    • Make sure to cut just below the light board.
    • To install the new light board, you will need to splice or solder the wires to the new light board.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Kyle Burwell
회원 가입일: 01/20/15
173 평판
안내서 1개 작성함
USF Tampa, Team 19-2, Blackwell Winter 2015 USF Tampa, Team 19-2, Blackwell Winter 2015 회원
USFT-BLACKWELL-W15S19G2
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 4
전체 시간: 180
