소개
This guide will teach you how to safely cut wires to remove the LED light panel component from the rest of the device and replace it with a new one.
필요한 것
Press down firmly to remove the battery cover and display battery.
Then remove the battery.
Place the plastic opening tool in between the two plastic panels and slowly work your way around the device.
Unlatch the clips on the inside and pull device apart.
With the back cover of the device removed, lightly pull up on the LED assembly to lift it out of its housing.
The LED assembly will separate into three components; the light board, outer housing, and plastic lens.
다른 한 분이 해당 안내서를 완성하였습니다.
