주요 콘텐츠로 건너뛰기
Nokero N400 Solar Panel Replacement
필요한 것
  1. Nokero N400 Solar Panel Replacement, Remove Battery Cover: 1 단계, 이미지 1/3 Nokero N400 Solar Panel Replacement, Remove Battery Cover: 1 단계, 이미지 2/3 Nokero N400 Solar Panel Replacement, Remove Battery Cover: 1 단계, 이미지 3/3
    • Press down firmly to remove the battery cover and display battery.
    • Then remove the battery.
  2. Nokero N400 Solar Panel Replacement, Unscrew Back Cover: 2 단계, 이미지 1/2 Nokero N400 Solar Panel Replacement, Unscrew Back Cover: 2 단계, 이미지 2/2
    • Remove the 7mm Phillips #1 screw.
  3. Nokero N400 Solar Panel Replacement, Pry Open Back Cover: 3 단계, 이미지 1/2 Nokero N400 Solar Panel Replacement, Pry Open Back Cover: 3 단계, 이미지 2/2
    • Place the plastic opening tool in between the two plastic panels and slowly work your way around the device.
    • Unlatch the clips on the inside and pull device apart.
    • Some clips will break when forced open.
  4. Nokero N400 Solar Panel Replacement, Solar Panel: 4 단계, 이미지 1/2 Nokero N400 Solar Panel Replacement, Solar Panel: 4 단계, 이미지 2/2
    • Pull the panel away from the rest of the assembly and cut the red and black wires coming from the panel
    • Be careful not to cut the ground-wire for the motherboard, it is the same color and goes to the exact same place as the solar panel wire.
    • For reassembly you will need to either splice, or solder the wires onto the replacement.
결론
Daniel Bumiller
회원 가입일: 01/20/15
201 평판
안내서 2개 작성하였습니다
USF Tampa, Team 19-2, Blackwell Winter 2015 USF Tampa, Team 19-2, Blackwell Winter 2015 회원
USFT-BLACKWELL-W15S19G2
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 5
전체 시간: 137
