주요 콘텐츠로 건너뛰기
Nokero N400 Suction Cup Replacement
필요한 것
  1. Nokero N400 Suction Cup Replacement, Remove Battery Cover: 1 단계, 이미지 1/3 Nokero N400 Suction Cup Replacement, Remove Battery Cover: 1 단계, 이미지 2/3 Nokero N400 Suction Cup Replacement, Remove Battery Cover: 1 단계, 이미지 3/3
    • Press down firmly to remove the battery cover and display battery.
    • Then remove the battery.
  2. Nokero N400 Suction Cup Replacement, Unscrew Back Cover: 2 단계, 이미지 1/2 Nokero N400 Suction Cup Replacement, Unscrew Back Cover: 2 단계, 이미지 2/2
    • Remove the 7mm Phillips #1 screw.
  3. Nokero N400 Suction Cup Replacement, Pry Open Back Cover: 3 단계, 이미지 1/2 Nokero N400 Suction Cup Replacement, Pry Open Back Cover: 3 단계, 이미지 2/2
    • Place the plastic opening tool in between the two plastic panels and slowly work your way around the device.
    • Unlatch the clips on the inside and pull device apart.
    • Some clips will break when forced open.
  4. Nokero N400 Suction Cup Replacement, Begin Removal: 4 단계, 이미지 1/2 Nokero N400 Suction Cup Replacement, Begin Removal: 4 단계, 이미지 2/2
    • Using tweezers, push the edges of the back end of the suction cup inward.
  5. Nokero N400 Suction Cup Replacement, Remove Suction Cup: 5 단계, 이미지 1/2 Nokero N400 Suction Cup Replacement, Remove Suction Cup: 5 단계, 이미지 2/2
    • Flip the cover over and remove the suction cup by pulling at an angle.
    • Be careful not to tear the plastic housing.
    • During reassembly, make sure to press down uniformly on the suction cup for an even fit.
결론
Daniel Bumiller
회원 가입일: 01/20/15
201 평판
안내서 2개 작성하였습니다
USF Tampa, Team 19-2, Blackwell Winter 2015 USF Tampa, Team 19-2, Blackwell Winter 2015 회원
USFT-BLACKWELL-W15S19G2
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 4
전체 시간: 121
