주요 콘텐츠로 건너뛰기
Nokero Shavano N220 Batteries Replacement
필요한 것
  1. Nokero Shavano N220 Batteries Replacement, Batteries: 1 단계, 이미지 1/3 Nokero Shavano N220 Batteries Replacement, Batteries: 1 단계, 이미지 2/3 Nokero Shavano N220 Batteries Replacement, Batteries: 1 단계, 이미지 3/3
    • Use one hand to hold the device still and the other to remove the lid by turning it clockwise using your index finger and thumb.
  2. Nokero Shavano N220 Batteries Replacement: 2 단계, 이미지 1/3 Nokero Shavano N220 Batteries Replacement: 2 단계, 이미지 2/3 Nokero Shavano N220 Batteries Replacement: 2 단계, 이미지 3/3
    • Using your index finger and thumb, squeeze the top and bottom of the plastic bezel together, and lift it off of the device.
  3. Nokero Shavano N220 Batteries Replacement: 3 단계, 이미지 1/3 Nokero Shavano N220 Batteries Replacement: 3 단계, 이미지 2/3 Nokero Shavano N220 Batteries Replacement: 3 단계, 이미지 3/3
    • Insert a spudger into the slot at the bottom of the lower battery cover, and pry the cover up.
    • You only need to apply minimal pressure to lift the cover. If you force it too hard, you may snap the plastic.
    • Repeat for the second battery cover.
  4. Nokero Shavano N220 Batteries Replacement: 4 단계, 이미지 1/3 Nokero Shavano N220 Batteries Replacement: 4 단계, 이미지 2/3 Nokero Shavano N220 Batteries Replacement: 4 단계, 이미지 3/3
    • Use a spudger or your fingers to remove the two batteries.
  5. Nokero Shavano N220 Batteries Replacement: 5 단계, 이미지 1/3 Nokero Shavano N220 Batteries Replacement: 5 단계, 이미지 2/3 Nokero Shavano N220 Batteries Replacement: 5 단계, 이미지 3/3
    • Now take your new batteries or let the old ones charge and reinsert them.
    • Follow the picture of the battery on the inside of the device.
  6. Nokero Shavano N220 Batteries Replacement: 6 단계, 이미지 1/3 Nokero Shavano N220 Batteries Replacement: 6 단계, 이미지 2/3 Nokero Shavano N220 Batteries Replacement: 6 단계, 이미지 3/3
    • Once you have put in both sides, insert the covers.
    • Match the ends and it should just pop into place.
  7. Nokero Shavano N220 Batteries Replacement: 7 단계, 이미지 1/3 Nokero Shavano N220 Batteries Replacement: 7 단계, 이미지 2/3 Nokero Shavano N220 Batteries Replacement: 7 단계, 이미지 3/3
    • Almost there, now take the white piece that you set aside and squeeze one side once again using your pointer finger and thumb to put it in.
    • Take the lid and turn it counter clockwise using your index finger and thumb.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Erica Hill
회원 가입일: 10/28/13
523 평판
안내서 5개 작성하였습니다
University of Maryland, Team 4-3, Vijaybhaskar Fall 2013 University of Maryland, Team 4-3, Vijaybhaskar Fall 2013 회원
UMD-VIJAYBHASKAR-F13S4G3
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 8
전체 시간: 371
