주요 콘텐츠로 건너뛰기
Nokero SunRay Pro Power Panel Front and Back Case Replacement
필요한 것
  1. Nokero SunRay Pro Power Panel Front and Back Case Replacement, Front and Back Case: 1 단계, 이미지 1/1
    • Turn over the device so that the back of the device is facing up.
  2. Nokero SunRay Pro Power Panel Front and Back Case Replacement: 2 단계, 이미지 1/3 Nokero SunRay Pro Power Panel Front and Back Case Replacement: 2 단계, 이미지 2/3 Nokero SunRay Pro Power Panel Front and Back Case Replacement: 2 단계, 이미지 3/3
    • Insert the first plastic opening tool along the side to pry open the case.
    • Sliding the plastic opening tool, while inserted, along the seam may help the removal process.
    • Use a second plastic opening tool to help separate the remaining seams.
  3. Nokero SunRay Pro Power Panel Front and Back Case Replacement: 3 단계, 이미지 1/2 Nokero SunRay Pro Power Panel Front and Back Case Replacement: 3 단계, 이미지 2/2
    • There is a long strip of double sided adhesive foam tape that prevents the back case from easily being removed.
    • Pull the back case off by applying steady pressure to remove it from the adhesive foam tape.
  4. Nokero SunRay Pro Power Panel Front and Back Case Replacement: 4 단계, 이미지 1/2 Nokero SunRay Pro Power Panel Front and Back Case Replacement: 4 단계, 이미지 2/2
    • Use the Phillips precision screwdriver to unscrew the two 5.0 mm Phillips screws from the circuit board.
    • Remove the solar panel and circuit board from the front case.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Jeremy
회원 가입일: 01/21/15
157 평판
안내서 1개 작성함
USF Tampa, Team 9-3, Blackwell Winter 2015 USF Tampa, Team 9-3, Blackwell Winter 2015 회원
USFT-BLACKWELL-W15S9G3
3 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 186
