주요 콘텐츠로 건너뛰기
Nokia 1100b RH-36 Motherboard and Keyboard Replacement
필요한 것
  1. Nokia 1100b RH-36 Motherboard and Keyboard Replacement, Battery Cover: 1 단계, 이미지 2개 중 1개 Nokia 1100b RH-36 Motherboard and Keyboard Replacement, Battery Cover: 1 단계, 이미지 2개 중 2개
    • Flip the phone over so that the screen faces down.
    • Press the gray button on the battery cover and slide it down off the back of the phone.
  2. Nokia 1100b RH-36 Motherboard and Keyboard Replacement, Battery: 2 단계, 이미지 1개 중 1개
    • Wedge the flat end of the spudger into the small indent next to the Nokia logo on the battery.
    • Gently pry the battery out of the phone.
  3. Nokia 1100b RH-36 Motherboard and Keyboard Replacement, Inner Casing: 3 단계, 이미지 2개 중 1개 Nokia 1100b RH-36 Motherboard and Keyboard Replacement, Inner Casing: 3 단계, 이미지 2개 중 2개
    • Remove the six 6mm T6 Torx screws around the edge of the front of the phone.
    • Remove the metal frame holding the screen and speaker.
  4. Nokia 1100b RH-36 Motherboard and Keyboard Replacement, Motherboard and Keyboard: 4 단계, 이미지 2개 중 1개 Nokia 1100b RH-36 Motherboard and Keyboard Replacement, Motherboard and Keyboard: 4 단계, 이미지 2개 중 2개
    • Gently lift motherboard unit out of the case.
    • The motherboard and keyboard are one unit and are replaced together.
결론
다른 13명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
James Szelenyi
회원 가입일: 04/19/13
286 평판
안내서 1개를 작성함
Cal Poly, Team 10-43, Amido Spring 2013 Cal Poly, Team 10-43, Amido Spring 2013 회원
CPSU-AMIDO-S13S10G43
4 회원들
안내서 14개를 작성함
1가이드 댓글
you nokia 1100 mother board please soon date…?
ajay gupta - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 10
지난 30일: 31
전체 시간: 4,932
