주요 콘텐츠로 건너뛰기
Nokia 1100b RH-36 Motherboard and Keyboard Replacement
필요한 것
  1. Nokia 1100b RH-36 Motherboard and Keyboard Replacement, Battery Cover: 1 단계, 이미지 1/2 Nokia 1100b RH-36 Motherboard and Keyboard Replacement, Battery Cover: 1 단계, 이미지 2/2
    • Flip the phone over so that the screen faces down.
    • Press the gray button on the battery cover and slide it down off the back of the phone.
  2. Nokia 1100b RH-36 Motherboard and Keyboard Replacement, Battery: 2 단계, 이미지 1/1
    • Wedge the flat end of the spudger into the small indent next to the Nokia logo on the battery.
    • Gently pry the battery out of the phone.
  3. Nokia 1100b RH-36 Motherboard and Keyboard Replacement, Inner Casing: 3 단계, 이미지 1/2 Nokia 1100b RH-36 Motherboard and Keyboard Replacement, Inner Casing: 3 단계, 이미지 2/2
    • Remove the six 6mm T6 Torx screws around the edge of the front of the phone.
    • Remove the metal frame holding the screen and speaker.
    You please Nokia 1100 Motherboard and keyboard Rely
    ajay gupta - 답글
  4. Nokia 1100b RH-36 Motherboard and Keyboard Replacement, Motherboard and Keyboard: 4 단계, 이미지 1/2 Nokia 1100b RH-36 Motherboard and Keyboard Replacement, Motherboard and Keyboard: 4 단계, 이미지 2/2
    • Gently lift motherboard unit out of the case.
    • The motherboard and keyboard are one unit and are replaced together.
결론
다른 12명이 해당 안내서를 완성하였습니다.
James Szelenyi
회원 가입일: 04/19/13
262 평판
안내서 1개 작성함
Cal Poly, Team 10-43, Amido Spring 2013 Cal Poly, Team 10-43, Amido Spring 2013 회원
CPSU-AMIDO-S13S10G43
4 회원들
안내서 14개 작성하였습니다
댓글 한 개
you nokia 1100 mother board please soon date…?
ajay gupta - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 24
전체 시간: 4,243
