주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nokia 2115i Motherboard Replacement
필요한 것
    1. Nokia 2115i Motherboard Replacement, Nokia 2115i Battery: 1 단계, 이미지 3개 중 1개 Nokia 2115i Motherboard Replacement, Nokia 2115i Battery: 1 단계, 이미지 3개 중 2개 Nokia 2115i Motherboard Replacement, Nokia 2115i Battery: 1 단계, 이미지 3개 중 3개
      • To prevent shock, press down on the power button located on the top of the phone until the phone shuts off.
      • Press down on the small gray button located on the back of the phone.
      • Slide the back plate down and off.
      댓글 쓰기
    2. Nokia 2115i Motherboard Replacement: 2 단계, 이미지 2개 중 1개 Nokia 2115i Motherboard Replacement: 2 단계, 이미지 2개 중 2개
      • To remove the battery, begin by holding the phone sideways.
      • Then, insert your thumb in the groove below the battery and push the battery up and out.
      댓글 쓰기
    1. Nokia 2115i Motherboard Replacement, Faceplate: 3 단계, 이미지 3개 중 1개 Nokia 2115i Motherboard Replacement, Faceplate: 3 단계, 이미지 3개 중 2개 Nokia 2115i Motherboard Replacement, Faceplate: 3 단계, 이미지 3개 중 3개
      • Locate the spudger. A photo of the correct spudger is provided to the left.
      • Turn the front of the phone to face you. Find the two small square holes on the bottom left and right sides of the faceplate.
      • Insert the spudger into each square hole and push up to detach the face plate.
      댓글 쓰기
    1. Nokia 2115i Motherboard Replacement, Removing the Keypad: 4 단계, 이미지 2개 중 1개 Nokia 2115i Motherboard Replacement, Removing the Keypad: 4 단계, 이미지 2개 중 2개
      • Note: The keypad will be loose and may fall off during this step.
      • Pull the face plate up and off of the phone.
      • To remove the keypad, simply lift it off the phone.
      댓글 쓰기
    1. Nokia 2115i Motherboard Replacement, Removing the Motherboard: 5 단계, 이미지 2개 중 1개 Nokia 2115i Motherboard Replacement, Removing the Motherboard: 5 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      • Locate the 6 screws on the metallic sheet that previously held the keypad. (This sheet, shown in the pictures, is the top side of the motherboard).
      • Note: 2 of the screws are on the bottom corners, 2 are on the right and left edges of the phone below the screen, and 2 are on the very top corners of the phone, above the screen.
      • Warning: The middle two screws are attached to the base of the phone with two black plastic rings. Use tweezers to remove the screws carefully to avoid breaking the plastic rings
      • Use a size T6 Torx screwdriver to remove each of these 6 screws.
      댓글 쓰기
    2. Nokia 2115i Motherboard Replacement: 6 단계, 이미지 3개 중 1개 Nokia 2115i Motherboard Replacement: 6 단계, 이미지 3개 중 2개 Nokia 2115i Motherboard Replacement: 6 단계, 이미지 3개 중 3개
      • To remove the motherboard, lift it up and off the phone.
      • Note: The screen will still be attached to the motherboard.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
6다른 기여자 명과 함께
Shane
회원 가입일: 09/30/10
80 평판
안내서 6개를 작성함
Cal Poly, Team 14-38, Forte Fall 2010 Cal Poly, Team 14-38, Forte Fall 2010 회원
CPSU-FORTE-F10S14G38
5 회원들
안내서 18개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 25
전체 시간: 3,366
