주요 콘텐츠로 건너뛰기
Nokia 2115i keypad replacement
필요한 것
  1. Nokia 2115i keypad replacement, Nokia 2115i Battery: 1 단계, 이미지 1/3 Nokia 2115i keypad replacement, Nokia 2115i Battery: 1 단계, 이미지 2/3 Nokia 2115i keypad replacement, Nokia 2115i Battery: 1 단계, 이미지 3/3
    • To prevent shock, press down on the power button located on the top of the phone until the phone shuts off.
    • Press down on the small gray button located on the back of the phone.
    • Slide the back plate down and off.
  2. Nokia 2115i keypad replacement: 2 단계, 이미지 1/2 Nokia 2115i keypad replacement: 2 단계, 이미지 2/2
    • To remove the battery, begin by holding the phone sideways.
    • Then, insert your thumb in the groove below the battery and push the battery up and out.
  3. Nokia 2115i keypad replacement, Faceplate: 3 단계, 이미지 1/3 Nokia 2115i keypad replacement, Faceplate: 3 단계, 이미지 2/3 Nokia 2115i keypad replacement, Faceplate: 3 단계, 이미지 3/3
    • Locate the spudger. A photo of the correct spudger is provided to the left.
    • Turn the front of the phone to face you. Find the two small square holes on the bottom left and right sides of the faceplate.
    • Insert the spudger into each square hole and push up to detach the face plate.
  4. Nokia 2115i keypad replacement, Removing the Keypad: 4 단계, 이미지 1/2 Nokia 2115i keypad replacement, Removing the Keypad: 4 단계, 이미지 2/2
    • Note: The keypad will be loose and may fall off during this step.
    • Pull the face plate up and off of the phone.
    • To remove the keypad, simply lift it off the phone.
결론
Shane
회원 가입일: 09/30/10
80 평판
안내서 6개 작성하였습니다
Cal Poly, Team 14-38, Forte Fall 2010 Cal Poly, Team 14-38, Forte Fall 2010 회원
CPSU-FORTE-F10S14G38
5 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 18
전체 시간: 1,029
