주요 콘텐츠로 건너뛰기
Nokia 2128i Internal Clock Battery Replacement
필요한 것
  1. Nokia 2128i Internal Clock Battery Replacement, Battery: 1 단계, 이미지 1/3 Nokia 2128i Internal Clock Battery Replacement, Battery: 1 단계, 이미지 2/3 Nokia 2128i Internal Clock Battery Replacement, Battery: 1 단계, 이미지 3/3
    • Be sure cell phone is off before you begin to disassemble the phone.
    • Press the button on the bottom of the back of the cell phone.
    • Slide rear panel down and remove it.
  2. Nokia 2128i Internal Clock Battery Replacement: 2 단계, 이미지 1/3 Nokia 2128i Internal Clock Battery Replacement: 2 단계, 이미지 2/3 Nokia 2128i Internal Clock Battery Replacement: 2 단계, 이미지 3/3
    • Using your fingernail, pry the back of the battery upwards and pull out.
  3. Nokia 2128i Internal Clock Battery Replacement, Faceplate: 3 단계, 이미지 1/3 Nokia 2128i Internal Clock Battery Replacement, Faceplate: 3 단계, 이미지 2/3 Nokia 2128i Internal Clock Battery Replacement, Faceplate: 3 단계, 이미지 3/3
    • Insert the plastic opening tool under the faceplate.
    • Separate the faceplate from main body by twisting the prying tool with some force.
    • The faceplate is held by three plastic fasteners, so pry evenly on both sides of phone.
  4. Nokia 2128i Internal Clock Battery Replacement, Keypad: 4 단계, 이미지 1/3 Nokia 2128i Internal Clock Battery Replacement, Keypad: 4 단계, 이미지 2/3 Nokia 2128i Internal Clock Battery Replacement, Keypad: 4 단계, 이미지 3/3
    • With the faceplate removed, simply peel off rubber key pad and remove.
  5. Nokia 2128i Internal Clock Battery Replacement, Motherboard Assembly: 5 단계, 이미지 1/3 Nokia 2128i Internal Clock Battery Replacement, Motherboard Assembly: 5 단계, 이미지 2/3 Nokia 2128i Internal Clock Battery Replacement, Motherboard Assembly: 5 단계, 이미지 3/3
    • Locate and remove the six screws on the front of the phone using a T6 Torx.
    • All 6 screws are 6.9mm long.
  6. Nokia 2128i Internal Clock Battery Replacement: 6 단계, 이미지 1/3 Nokia 2128i Internal Clock Battery Replacement: 6 단계, 이미지 2/3 Nokia 2128i Internal Clock Battery Replacement: 6 단계, 이미지 3/3
    • After removing screws, lift the motherboard assembly straight off the cell phone body.
  7. Nokia 2128i Internal Clock Battery Replacement, Internal Clock Battery: 7 단계, 이미지 1/2 Nokia 2128i Internal Clock Battery Replacement, Internal Clock Battery: 7 단계, 이미지 2/2
    • With the logic board completely removed, gently pry out the internal clock battery from its housing.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Curtis Lutje
회원 가입일: 10/07/10
28 평판
안내서 6개 작성하였습니다
Cal Poly, Team 20-8, Maness Fall 2010 Cal Poly, Team 20-8, Maness Fall 2010 회원
CPSU-MANESS-F10S20G8
4 회원들
안내서 24개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 3,363
