부품
부품은 필요하지 않습니다.
Insert the plastic opening tool under the faceplate.
  • Insert the plastic opening tool under the faceplate.
  • Separate the faceplate from main body by twisting the prying tool with some force.
  • The faceplate is held by three plastic fasteners, so pry evenly on both sides of phone.
댓글 쓰기
With the faceplate removed, simply peel off rubber key pad and remove.
  • With the faceplate removed, simply peel off rubber key pad and remove.
댓글 쓰기
  • Locate and remove the six screws on the front of the phone using a T6 Torx.
    • All 6 screws are 6.9mm long.
댓글 쓰기
  • After removing screws, lift the motherboard assembly straight off the cell phone body.
댓글 쓰기
  • Be sure cell phone is off before you begin to disassemble the phone.
  • Press the button on the bottom of the back of the cell phone.
  • Slide rear panel down and remove it.
댓글 쓰기
  • Using your fingernail, pry the back of the battery upwards and pull out.
댓글 쓰기
  • With the LCD unit removed, gently press out the speaker with a non-metallic pointed object.
댓글 쓰기
결론
Andres Echeverria
회원 가입일: 2010년 10월 29일
4 평판
안내서 3개 작성하였습니다
Cal Poly, Team 20-8, Maness Fall 2010 Cal Poly, Team 20-8, Maness Fall 2010 회원
CPSU-MANESS-F10S20G8
4 회원들
안내서 28개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 217
