주요 콘텐츠로 건너뛰기
Nokia 2128i Power Unit Replacement
필요한 것
  1. Nokia 2128i Power Unit Replacement, Battery: 1 단계, 이미지 1/3 Nokia 2128i Power Unit Replacement, Battery: 1 단계, 이미지 2/3 Nokia 2128i Power Unit Replacement, Battery: 1 단계, 이미지 3/3
    • Be sure cell phone is off before you begin to disassemble the phone.
    • Press the button on the bottom of the back of the cell phone.
    • Slide rear panel down and remove it.
  2. Nokia 2128i Power Unit Replacement: 2 단계, 이미지 1/3 Nokia 2128i Power Unit Replacement: 2 단계, 이미지 2/3 Nokia 2128i Power Unit Replacement: 2 단계, 이미지 3/3
    • Using your fingernail, pry the back of the battery upwards and pull out.
  3. Nokia 2128i Power Unit Replacement, Faceplate: 3 단계, 이미지 1/3 Nokia 2128i Power Unit Replacement, Faceplate: 3 단계, 이미지 2/3 Nokia 2128i Power Unit Replacement, Faceplate: 3 단계, 이미지 3/3
    • Insert the plastic opening tool under the faceplate.
    • Separate the faceplate from main body by twisting the prying tool with some force.
    • The faceplate is held by three plastic fasteners, so pry evenly on both sides of phone.
  4. Nokia 2128i Power Unit Replacement, Keypad: 4 단계, 이미지 1/3 Nokia 2128i Power Unit Replacement, Keypad: 4 단계, 이미지 2/3 Nokia 2128i Power Unit Replacement, Keypad: 4 단계, 이미지 3/3
    • With the faceplate removed, simply peel off rubber key pad and remove.
  5. Nokia 2128i Power Unit Replacement, Motherboard Assembly: 5 단계, 이미지 1/3 Nokia 2128i Power Unit Replacement, Motherboard Assembly: 5 단계, 이미지 2/3 Nokia 2128i Power Unit Replacement, Motherboard Assembly: 5 단계, 이미지 3/3
    • Locate and remove the six screws on the front of the phone using a T6 Torx.
    • All 6 screws are 6.9mm long.
  6. Nokia 2128i Power Unit Replacement: 6 단계, 이미지 1/3 Nokia 2128i Power Unit Replacement: 6 단계, 이미지 2/3 Nokia 2128i Power Unit Replacement: 6 단계, 이미지 3/3
    • After removing screws, lift the motherboard assembly straight off the cell phone body.
  7. Nokia 2128i Power Unit Replacement, Power Button: 7 단계, 이미지 1/3 Nokia 2128i Power Unit Replacement, Power Button: 7 단계, 이미지 2/3 Nokia 2128i Power Unit Replacement, Power Button: 7 단계, 이미지 3/3
    • With the motherboard and LCD unit removed, gently pull the power button out of its housing.
  8. Nokia 2128i Power Unit Replacement, Power Unit: 8 단계, 이미지 1/3 Nokia 2128i Power Unit Replacement, Power Unit: 8 단계, 이미지 2/3 Nokia 2128i Power Unit Replacement, Power Unit: 8 단계, 이미지 3/3
    • Flip phone over and find the sticker that holds the metallic plating together with the phone's case.
    • Pry off the portion of the sticker that is attached to the phone's case. Do not worry about removing the sticker from the metallic plate.
  9. Nokia 2128i Power Unit Replacement: 9 단계, 이미지 1/3 Nokia 2128i Power Unit Replacement: 9 단계, 이미지 2/3 Nokia 2128i Power Unit Replacement: 9 단계, 이미지 3/3
    • Locate the small hook that holds the metallic plate and phone case together on the front side of the phone
    • Place your thumbs on the backside of the metallic plate.
    • Stretch phone casing outward to detach hook from metallic plating. Simultaneously push metallic plate outward to remove.
  10. Nokia 2128i Power Unit Replacement: 10 단계, 이미지 1/3 Nokia 2128i Power Unit Replacement: 10 단계, 이미지 2/3 Nokia 2128i Power Unit Replacement: 10 단계, 이미지 3/3
    • Pry out the power unit once the metallic plate has been removed.
  11. Nokia 2128i Power Unit Replacement: 11 단계, 이미지 1/1
    • Be sure to place the power unit back into the phone's case with the gold hardware pointing upward.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Andres Echeverria
회원 가입일: 10/29/10
4 평판
안내서 1개 작성함
Cal Poly, Team 20-8, Maness Fall 2010 Cal Poly, Team 20-8, Maness Fall 2010 회원
CPSU-MANESS-F10S20G8
4 회원들
안내서 24개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 2
전체 시간: 632
